01-08-2017, 12:46 PM
How much power can you squeeze out of a 986 Boxster S?
We fit a sports exhaust, 987 airbox and 996 throttle body to a 986 Boxster S. What's the final horsepower figure?
https://www.youtube.com/watch?v=kja5LSsUT_g
01-08-2017, 01:38 PM
very nice. i would question the role that the old tune is playing - both in increased hp, and in the fueling issues. on an unmodified ecu you should be running at stoichometric at low load (to say 4000 rpm) regardless of what you have done to the intake - air and fuel mix is monitored by 02 sensors and kept at stoichometric. you can make the intake and exhaust paths bigger, but the amount of air can still be measured. even if the amount of air is not being monitored properly (ie maf issues, air leaks, etc.) the ecu will trim (add/subtract fuel) to try and maintain stioch. if ecu finds itself having to add/subtract more that 20% or 25% fuel to maintain stoich then you will get a cel. so, you have no cel and are not running at stoich at low load - it must be the aftermarket tune.
i ran that same arrangement and monitored my idle and low load trims and everything stayed well within acceptable ranges.
01-08-2017, 05:38 PM
Neil,
Great videos...
It wasn't explicitly clear.....Is your buddy running a 987 MAF housing with the standard diameter? 80mm diameter was mentioned. How are you deeming the engine to be running rich?
986 00S
01-08-2017, 05:55 PM
Ben-Auto-Design
Nice!
I haven't had time to watch it completely, I jumped straight to the end, but it is some nice gains!
But... you've remapped it before the mods???
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
01-09-2017, 01:32 PM
Nice video. So, do I understand YouTube correctly-this part 1 was posted 4 days ago and parts 2 and 3 are still to come?
Ben, my understanding is the car was bought with the exhaust upgrade and tune already installed-the plenum and TB were added by the current owner. Parts 2 & 3will be interesting to see how it all turns out.
01-09-2017, 06:45 PM
Neil's videos are clean uncomplicated, easy to understand and succinct.
Good job!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
01-19-2017, 01:04 AM
Originally Posted by jaykay
Neil,
Great videos...
Thanks Jay! Richard is running the 987 airbox but has kept the MAF and housing from the original airbox to try to avoid any ECU problems.
01-19-2017, 01:06 AM
Originally Posted by Ben006
Nice!
The previous owner did it before Richard bought the car. We will discuss this in part 3 - stay tuned!
01-19-2017, 01:07 AM
Cheers Paul! Yep, part 2 goes up today and part 3 in the next week.
01-19-2017, 01:09 AM
Originally Posted by Gelbster
So kind Gelbster! Glad you like them!
01-19-2017, 01:13 AM
Part two is now up! Does fitting an underdrive pulley give more horsepower? We fit one then go to the rolling road to find out!
https://youtu.be/CvFdH11y4EI
01-19-2017, 07:58 AM
Is this 273 wheel hp or does the dyno convert to crankshaft hp?
01-19-2017, 08:00 AM
It is calculated, in one of the videos (maybe this one somewhere or another rolling road video, maybe the one with the 996) the dyno guy briefly changes the screen to show the actual wheel HP read by the dyno - it is a fair amount lower.
01-19-2017, 10:43 AM
So if I understand correctly, the Dyno's calculated total horsepower is still 273 after fitting the underdrive pulley. Do you have the wheel horsepower figures for before and after? Would like to see if there is a small bump in the net amount reaching the rear wheels, that is what I think the underdrive pulley gives you. (Besides saving your power steering pump at the track.)
PS, great video! If you decide to improve editing quality as discussed in the comments to the video, that would be a bonus, but they are teriffic as is!
01-19-2017, 11:31 AM
Yes, please post the wheel hp differences, if there are any.
01-19-2017, 12:43 PM
flywheel hp is extrapolated from wheel hp (ie, increase by 15%) so pretty arbitrary, and can mask/over-emphasize actual gains, esp when dealing with small hp changes. wheel hp is the best measure in these situations i think.
01-19-2017, 03:36 PM
The only thing the dyno can measure is wheel horsepower. If it shows crank horsepower its an estimate, depending on the dyno it can be a fixed offset or a percentage offset.
1941 Dodge Luxury Liner Coupe
01-19-2017, 07:51 PM
The take home from this is that Neil paid for a trick part+ a serp belt, hacked off a boss from the engine that is rather useful and spent a bunch of time and other money for no gain of any sort.
The Track guys would claim a benefit in not over-reving the p/s pump ?
The pro-u/d pulley guys claim there is no loss of cooling efficiency or a/c with driving those pulleys slower. Really?
At least Neil did not use the disintegrating version of the u/d pulley.He used a solid one.
I was surprised that when doing this project he did not check the bearings in all the other pullies & ancillaries. At least give the w/p pulley a wiggle ? Maybe that was done in another video?
If Neil wants a trick part that really works for about the same money, he should talk to Ben006 in Post #4- hint ! Ben;s trick part may work particularly well with the 987 bigger airbox?
01-19-2017, 11:02 PM
A dyno doesn't measure hp. It measures torque. HP are calculated from torque and rpm.
There are different parameters that can affect a measurement:
- Temperature
- Humidity
- Grip
- Fuel quality
- Air filter, sparks…
If you don't use a calibrated and certified dyno, measurements are just written lines on a piece of paper.
Funny how people are hunting for 5 hp at the top end. Useless to say that this doesn't affect the driveability of the approx. 250 hp car in any way.
But keep on searching. Always funny to me.
Just my 2 cents.
Markus
