Old 09-21-2016, 07:41 AM   #3
POG champ, 1995.
Outer CV Joint on the driver side half axle? A quick check is to get under there and look at the CV Joint boots to see if one has a tear, although it seems like that would have caught in the PPI.
Does turning the car one way or the other increase or reduce the noise? If so possible wheel bearing issue.
I'll have to try and pop my face under there this weekend and look for torn boots, thanks.
Makes no difference, straight or turning.
I had originally thought a bearing might be going.
But when I get the vehicle up to any speed, in my test around 50 mph, and let it coast in neutral, no noise at all.
Literally only when in gear, accel or decl, noise is there.
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
