Old 08-20-2016, 04:37 PM   #1
98 boxster not going into gear
Hello
Seeing if people on here can lead me in a good direction
I have a 98 boxster 2.5 5speed
Will not go into gear at all... car running or stopped.
Checked clutch libe cables seem to be fine. A friend of mine think is is the forks in the transmission.
Has anyone else ever had this issue.
Please help
Timmyk is offline   Reply With Quote
Old 08-20-2016, 04:59 PM   #2
There Is No Substitute.
rick3000's Avatar
Can you put the shifter into the correct gear location (ie - the shifter is fine, but the transmission is not going into gear), or are you unable to get the shifter into the correct place?
A somewhat common issue is for the transmission cable 'retainer' to break, which keeps the transmission from shifting into your chosen gear. I had it happen to me, it's a fairly simple fix, which was described to me as putting the cable back into place and securing it with a pipe clamp.
Old 08-21-2016, 04:16 AM   #3
First thing to check is the cable connections at the trans. If the cable outer sheath becomes separated from the clip that hold it to the case you get the symptoms you describe. If that is the problem you can snap the cable back into the clip and secure it with safety wire. Could also be the very end of the inner cable popped off the lever on the trans, but this is less likely.
Deadeye is offline   Reply With Quote
Old 08-21-2016, 08:56 PM   #4
To add what I have done. Once I disconnected the cables at transmission. I checked for correct cable and shifter operation minus the transmission of course. Shifter and cables work perfect when trans is disconnected from them.
Old 08-21-2016, 08:57 PM   #5
When connected to trans they are stuck in neutral. The shift rod sticking out of trans. There is only one. Is jammed. Cannot shift it by hand at the trans. Where as normally you can use one hand to shift through the gears at the trans.
Old 08-22-2016, 05:39 AM   #6
2003 S, Arctic Silver, M6
paulofto's Avatar
Have you checked your trans oil level or condition?
Old 08-22-2016, 12:22 PM   #7
Put the rear up on jack stands. Rotate one wheel back and forth while you wiggle the transmission shifter lever on the side of the transmission. That may free up the mechanism. Are you sure the lever is actually moving the shaft that goes through the trans case?
Old 01-31-2017, 07:47 AM   #8
my Mechanic has taken apart the transmission looks like a bent shift rod, does anyone know if you can buy the rods separately does does it come as a kit
Old 01-31-2017, 09:10 AM   #9
Try little heat to straighten the bent one ?
How did you bend it?
You need to figure that out before you put a new one in -and bend that one also !
Perhaps some careful inspection of the cables for damage and a little silicone grease?
Old 01-31-2017, 10:26 AM   #10
Sorry, I missed the bent rod post
Last edited by porsches2944; 01-31-2017 at 10:40 AM. Reason: didn't see previous post
porsches2944 is offline   Reply With Quote
