Old 07-17-2016, 03:41 AM   #1
Parking Brake Adjustment
First I've searched all the forums, read the DIY on Pelican's sight and referenced my manuals.
I'm trying to adjust my parking brake, as it only engages at the very last click at the top of the range of motion. For the life of me I cannot loosen the two nuts under the storage are in the cockpit. Is simple brute force required? I am afraid i am going to break the mechanism. Any tricks or wisdom based on experience?
Jthoms1 is offline   Reply With Quote
Old 07-17-2016, 04:13 AM   #2
Oggie's Avatar
I would suggest checking that you still have some brake pad left on the parking brakes, by removing the rear discs. If they are OK, then I would tighten the park brakes by turning the wheel adjusters as per the diagram on this site.
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
Old 07-17-2016, 07:05 AM   #3
1999 base
Meir's Avatar
To answer your question, yes.
I takes a lot of force to get those two nuts separated.
Old 07-17-2016, 07:58 AM   #4
steved0x's Avatar
Agreed, two wrenches in opposite directions, it is hard. Place them in such a way that you can squeeze them.together with the palm of your hand.
