Old 01-19-2016, 05:52 PM   #1
987 Cat back exhaust; excess heat on the rear shocks?
Just installed a cat back exhaust on my 2007 Cayman S.
The factory pipe has a perforated heat shield. Is there enough heat off the pipe to cause concern for the rear shock?
west911 is offline   Reply With Quote
Old 01-21-2016, 11:37 AM   #2
Before I installed the SpeedArt cat back, I wrapped the pipes that pass right next to the bottom of the struts for the same reason..
Gilles is offline   Reply With Quote
Old 01-21-2016, 12:29 PM   #3
njbray's Avatar
When I put on my cat delete pipes I used a couple of these to keep the heat off the driveshaft rubber boots. They seem to work - I have waved my hand around the hot pipes and the seem to soak/ redirect a lot of the heat away. Of course the pipes don't get as hot as the cats did.
DEI Titanium Pipe Shield with LR Technology 010450 - Free Shipping on Orders Over $99 at Summit Racing
njbray is offline   Reply With Quote
Old 01-21-2016, 01:17 PM   #4
Steve Tinker's Avatar
Its not the shock that suffers heat stress but the inner rubber drive shaft boots - especially on the S models.
Mine lasted +/- 15,000 km before the rubber hardened and split....
Wrapping them is one way to reduce the heat buildup, but by far the best is to have the pipes ceramic coated both internally and externally.
2001 MV Agusta F4.
