Old 05-08-2006, 01:52 PM   #1
Dont knowwhat kind of Coolant to use?
I realized I needed coolant when my engine was overheating and steaming. It doesnt say what kind of coolant to use on the cap it says water and I dont know if im suppose to mix with coolant. Or what kind to use.
yellowboxster is offline   Reply With Quote
Old 05-08-2006, 05:11 PM   #2
Here's a link (I hope) that will explain it.
http://986forum.com/forums/showthread.php?t=3859
Zib
Biz-z Z is offline   Reply With Quote
Old 05-08-2006, 05:46 PM   #3
deliriousga's Avatar
If you're adding, I'd only use Porsche coolant. It's expensive, but mixing coolants is dangerous. You can change it over to another type of coolant with a complete flush and fill later.
1966 Wife White/Brown Top
Old 05-08-2006, 07:31 PM   #4
Don't just fill it and forget about this. Do get the cooling system checked out. You could have a leak in your coolant tank resoivor, a blown hose or just a loose clamp.
Motors are really expensive in comparison, so get to the source of the problem asap!
