Old 10-21-2015, 07:17 AM   #1
Swapping boxster clocks
Hi All
Hello everyone. I am a new member and would like your advice please
I would like to change my clock binnacle on my 2.7 986 boxster to a 3.2 s binnacle
I note that the 3.2 s has a max speed of 175mph and my 2.7 has a max speed of 150mph.
If I change would it show the correct speed I am traveling at and what about the digital speed display?
Has anyone done this, are there any other issues
Thanks for any advise on this
oldbones is offline   Reply With Quote
Old 10-21-2015, 07:39 AM   #2
I've never heard of anyone doing this, nor do I believe it to be possible. There is a project for adding the Carrera Gauge cluster so if you found a whole boxster s cluster I'm sure you could swap that in without issue.
Old 10-21-2015, 08:58 AM   #3
lkchris's Avatar
I believe he's actually writing about changing the whole cluster.
Some folks would call a speedometer a clock and maybe even a tachometer a clock.
In all the articles I've read about installing a 996 cluster, there hasn't been mention of a problem and surely they read to a higher speed than the 150 mph boxster.
It's surely the same digital input from wherever the speed sensor is and the cluster computes what it needs from that. It's not a mechanical cable.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 10-21-2015, 11:53 AM   #4
OK I interpreted it as him just wanting to swap the speedometer face. I'm sure you'd need to swap the entire cluster.
Old 10-21-2015, 12:51 PM   #5
Yes that's right I intend swapping my whole black 2.7boxster cluster for a 3.2s silver cluster and thought I'd check with you guys before I search through eBay
Old 10-21-2015, 02:37 PM   #6
Then that should work. Follow the same guidelines that the 996 swap would use, but you don't have to make room for the oil pressure or battery gauges.
Old 10-22-2015, 02:49 AM   #7
clocks swop
Great thanks for your advice, the swap looks straight forward and shouldn't take too long
Old 10-22-2015, 02:09 PM   #8
Just had a thought if I install a replacement binicle (set of clocks) will the displayed mileage be that of the new binicle has recorded or is my current mileage saved on the ecu and so will be transferred to the new binicle.
I don't want the replace the binicle and find a higher mileage is displayed
Old 10-27-2015, 10:37 AM   #9
Simply speaking if I buy a second hand set of clocks to replace my existing tempromental set will the mileage remain the same or reflect the mileage on the replacement set
Anyone any idea
Old 10-27-2015, 03:27 PM   #10
EJ-Fresno's Avatar
The mileage displayed will be the one on the replacement clock.
You will to reprogram the EPROM to insert your actual mileage.
In addition, if your car is a 2003+, you will have to encode the VIN otherwise your radio will not turn on.
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
