Old 08-28-2015, 02:33 PM   #1
BOOTLEG's Avatar
Question Tiptronic engine OK in 6 speed?
In searching for a replacement 3.2L for my 6 speed 2001S, I find many coming from donor cars with a Tiptronic. Will these work with a 6 speed by simply switching the flex plate for a clutch & PP?
BOOTLEG is offline   Reply With Quote
Old 08-28-2015, 02:47 PM   #2
BYprodriver's Avatar
Yes, + the dual-mass flywheel. There is a additional coolant connection for the tiptronic, just put the 2 engines side by side & exchange the connecting part.
Old 08-28-2015, 09:12 PM   #3
Wiring harness is different too, but not a big deal if you have your old one.
Woody
Old 08-29-2015, 10:39 AM   #4
Vac tube routing bit different as well.
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
Old 08-29-2015, 10:44 AM   #5
+1 ^^^^ What he said.
IMHO, a Tip replacement engine is the best choice since it was likely driven in Auto at lower RPM's for most of its previous life. At least, that is my (unproven) theory.
Old 08-30-2015, 06:34 AM   #6
jsceash's Avatar
Been running this combination for 3 years. As others noted.
1.Transfer your C,P,F to the new motor or renew they bolt right up. You'll also need Flywheel bolt for a manual.
2.Transfer the engine wiring harness from the manual motor.
3.There is a 4 way "T" and 3 way "T" cooling hose on the Tip motor use the 3 way hose and the "L" shaped hose from the Manual motor.
4.The vacuum line on the tip at the intake has a 4 way tee use the manual 3 way "T" from the manual motor.
I believe that is it.
