Old 08-25-2015, 10:30 AM   #1
02 Boxster lower control arm broke
Driving to work yesterday in my 02 Boxster and I hit the brakes for a light and I hear a loud thump and rubbing at my driver's side front wheel area. Evidently my lower control arm snapped. Anyone ever heard of this happening?
Swodawg is offline   Reply With Quote
Old 08-25-2015, 10:48 AM   #2
Yeah, I've done that.
leftfield6's Avatar
Holy crap. That is a pretty robust looking part, I'm surprised it would snap like that without a much harder hit than just braking for a stop. Sure you haven't had another impact recently that may have cracked it? Maybe some road debris like a truck tire tread or something?
1999 Boxster, Tiptronic, Hard Top, Arctic Silver with Boxster Red Interior
leftfield6 is offline   Reply With Quote
Old 08-25-2015, 11:24 AM   #3
EJ-Fresno's Avatar
How many miles on the part? :O
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 08-25-2015, 11:41 AM   #4
wow
Swodaw,
I am glad that the control arm failed while breaking for a red light and not during a spirited drive through a canyon...
Old 08-25-2015, 02:12 PM   #5
The car has 50k miles. I just bought the car in March with 44k. So, I don't know if the car has been wrecked. I don't think I have hit anything.
Old 08-25-2015, 04:52 PM   #6
BYprodriver's Avatar
Better check the torque of the bolt that formerly attached it to the chassis.
Is it from Mobile? Salt water corrosion?
Old 08-25-2015, 09:43 PM   #7
Wow! I never would have guessed. I see both the lateral arm as well as the trailing arm have both just snapped right off there.
Old 08-25-2015, 09:48 PM   #8
Wow. Never seen something like that before. Especially from hitting brakes.
Because the lower control arm has a bearing i don't think that too much torque could have caused that.
I think you should investigate the complete car for accidents of a previous owner.
Regards
Markus
Old 08-26-2015, 09:04 AM   #9
It is not unheard of for GT3 LCAs to break in that area from lots of track use. Hard to imagine it happening with street use only. Maybe lots of potholes?
spendy is offline   Reply With Quote
Old 08-26-2015, 10:34 AM   #10
Regards
Markus
Is bearing Germ-english for bushing?
Old 08-26-2015, 12:05 PM   #11
Hi BYprodriver,
- damn, you're right. I've meant a bushing. Sorry.
Regards from Germany
Markus
Old 08-26-2015, 03:45 PM   #12
Hi BYprodriver,
Markus
OK, we like your input from the motherland, Danke schon!
I was wondering if it is possible to install a LCA in a bound position with enough torque on the bolt to cause this! Maybe with alot of corrosion?
Old 08-26-2015, 04:57 PM   #13
Wow, never thought a chunk of metal could break like that!
hancock1701 is offline   Reply With Quote
Old 09-08-2015, 11:53 AM   #14
Thought I would give an update, ended up having to replace the lower control arm, trailing arm, and had a bent tie rod. hopefully be back on the road soon...
Old 09-08-2015, 12:50 PM   #15
As Spendy mentioned, I have seen this happen on several Spec Boxster race cars. Some racers will replace the LCA's every two years as preventative maintenance.
