Old 05-26-2015, 07:38 AM   #1
996 instrument cluster
Was looking to change over to a 996 instrument cluster I'm in the UK and there's not many available so found one that will fit/work for sale in the U.S. Only difference seems to be the temperature gauge.
Then I see this on pelican tech page
"If you are located in the United States, be sure that you get a cluster that is a US-spec unit, and has the main speedometer gauge delimited in mph"
So are your speedos limited in the U.S. Then and won't read over a set speed.
whitecliffs is offline   Reply With Quote
Old 05-26-2015, 07:49 AM   #2
lkchris's Avatar
No, that was a poor choice of words-should have just written "indicated."
USA cluster will also have light that reads "brake" rather than with the icon for handbrake
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 05-26-2015, 07:51 AM   #3
inveniam viam aut faciam
No, they mean that speedometer reads mph, instead of kph as in other countries. I think using "delimited" is not the best choice of words. A US cluster would work fine for you, as long as you don't mind the temperature gauge being marketed in Fahrenheit rather than Celsius.
Qmulus is offline   Reply With Quote
Old 05-26-2015, 07:59 AM   #4
Great cheers for the replys
Old 05-26-2015, 10:36 AM   #5
Giller's Avatar
The speedo can switch between miles and kilometers for both the odometer and speedometer on the digital LCD screen (at least it did on mine, not sure if you need the OBC for that to work).
And the Fahrenheit piece really doesn't matter - if the needle points straight up, it's all good. Points too much to the right, bad.
My first Boxster was a US car that was imported over to Canada. No probs with the display.
