Old 05-02-2015, 08:17 AM   #3
with a '97 which has manual f/trunk levers you can slide a very thin screwdriver b/w the levers and rotate the locking pin (white) to side releasing the levers...
Otherwise
- try charging battery thru one of the cig lighter ports
- use emergency release cable (check to see if routed to tow hook if not orig owner)
Good luck
"Cool Prius!"
- Nobody
