Old 01-17-2015, 04:30 PM   #1
2000 boxster s stumbly idle
If it's a miss, its slight.
had Porsche plugs and coils done 12k miles ago
NO CEL
No codes on durametric
logged misfires, shows none
logged engine roughness, and it does fluctuate, but I don't know what is normal.
Any ideas?
Thanks!
stilov is offline   Reply With Quote
Old 01-17-2015, 04:43 PM   #2
Steve Tinker's Avatar
Try cleaning the throttle body & butterfly flap leading / trailing edge with carb / injector cleaner, that normally helps.......
2001 MV Agusta F4.
Old 01-17-2015, 04:49 PM   #3
That's an idea.
I still thought about plugs. Last summer I had s bad aos with a decent amount of oil in the manifold. Possibly fouled the plugs?
Old 01-17-2015, 05:01 PM   #4
steved0x's Avatar
There is a new DIY for throttle body cleaning in the DIY section. Totally fixed my idle problem which had been getting worse... Much easier than getting in to mess with the spark plugs in my opinion. Most recently the idle would get so stumbly it felt like the car was about the shut off, then the rpm would shoot up like a man desperately gulping air.
