Old 11-17-2014, 09:01 AM   #1
Can I use a 996 AOS on my 986s?
I'm asking this bc I know my 986 needs one soon. I have a almost new 996 AOS. The only difference is the two vacuum line ports on the top. Can I just leave those undone? Or is that going to cause the AOS not to work correctly?
My 986 AOS
My 996 AOS
Trendy996 is offline   Reply With Quote
Old 11-17-2014, 09:54 AM   #2
steved0x's Avatar
I thought those were ports for water cooling? I don't know the answer to your question though.
Old 11-17-2014, 10:26 AM   #3
Could be water cooling. It's been a while since I've done one on a 996 and my 996 is in a different state at the moment. If it's just water cooling Id imagine I should be ok. But I'll wait to see if some one chimes in with some knowledge 👍
Old 11-17-2014, 10:28 AM   #4
BYprodriver's Avatar
You can, the small connections are for coolant lines to warm it up. Boxsters rarely have that problem being mid-engine.
Old 11-17-2014, 11:35 AM   #5
Thanks for the info
