Old 10-20-2014, 03:24 PM   #1
Beginner
Jamesp's Avatar
Fun with a Durametric
Just plugged in my new Durametric for the first time. The car has been running a little weak and generally misbehaving. Idle falls as low as 600 rpm, surges to 1500 then stalls only occasionally when hot. The car has picked up the habit of losing some power after it gets hot, which comes and goes. It threw a valve timing code in the past, cleaned up, then threw another code. Here are some screen shots of the Durametric output:
Thoughts?
2003 S manual
Old 10-20-2014, 03:38 PM   #2
Did you get the cam deviation numbers?
Old 10-20-2014, 05:11 PM   #3
Beginner
Jamesp's Avatar
Rock solid - does not change with RPM.
What is the acceptable range?
2003 S manual
Old 10-20-2014, 06:40 PM   #4
steved0x's Avatar
I think -6 to +6, you are way within the acceptable range and steady is good.
