06-14-2014, 01:27 PM
2000 Boxster S Rear Reinforcement Plate
Hi everyone,
My first time starting a thread! I've acquired a 2000 Boxster S sans engine and transmission. I do have a lot of the rear suspension parts that were removed to get the engine/tranny out by the PO, but I know I'm missing a rather critical part - the rear reinforcement plate. I've tried searching Pelican Parts, but they don't seem to offer this replacement part; maybe it seldom "goes bad/missing".
Does anyone have any advice to locate this part? Am I calling it by the correct name to search for it on car-parts.com, ebay, or the forum?
Thanks for any help you can provide!
Alex
06-14-2014, 02:35 PM
6 98633116301 Bracket
(FOR YEAR 1997 & Up)
$300.93
(6) 98633116301 Bracket
(UP TO YEAR 99)
$300.93
(6) 98633116105 Bracket
(FROM YEAR 00 UP)
$300.93
M249
YEAR DESCRIPTION
1997-2004 TIPTRONIC TRANSMISSION
(FROM YEAR 00 UP)
$300.93
M480
YEAR DESCRIPTION
1997-2004 6-SPEED MANUAL TRANSMISSION
(FROM YEAR 00 UP)
M481
YEAR DESCRIPTION
1997-2004 5-SPEED MANUAL TRANSMISSION
- ... Spoiler
(UP TO YEAR 00)
2
Rear Axle Side Section Bracket
mike@lonestarrpm.com
06-14-2014, 02:41 PM
Artist, 986S tinkerer
06-14-2014, 04:37 PM
Beginner
Look in the parts section and pick up a used one. Plenty of folks parting out Boxsters.
2003 S manual
06-14-2014, 08:17 PM
Check with Woody, username itsnotanova, he has just about everything. Very professional and fast
06-14-2014, 08:21 PM
Lol, just found Woody while you were posting that reply. I'm sending him a PM right now. Thanks for the tips and part numbers! BTW, is it the same part number for 5 & 6 speed trannies?
06-16-2014, 07:49 AM
******************************************** has some easy to use part diagrams: [Edit: I should have checked the links above, everybody else already posted the link to them  ]
Porsche Boxster Parts
And when there are differences between base and S, or year differences, it will tell you.
Here is the diagram for that part:
It looks like there are different versions for tip and manual, but not between 5 and 6 speed. The part ending in 301 looks like it is the one you need.
Woody will know and make sure you get the right one.
06-17-2014, 10:21 AM
Thanks for the vote of confidence Steve! Unfortunately I'm still learning these things and didn't even notice a difference on the pans until I read this thread. After looking at all the plates I have, I have all 3 kinds. The difference seems to in the air baffles on top and not the aluminum plate. It also looks like the 5 speed was the only one that came with an heat shield on the vertical V brace too.
06-17-2014, 07:52 PM
inveniam viam aut faciam
Originally Posted by DennisAN
I guess I may be missing something, but the only parts catalogs I see there are pdfs on CD for older models. Is there something similar for later models?
06-17-2014, 08:28 PM
I didn't see any 986 stuff either.
On another note. I looked at all the aluminum plates I have and they all have the same part number with different dates stamped into them. part #98633126108. The baffle riveted to the aluminum plate has a different part number too. All three different baffles have different part numbers.
986.331.183.01
986.331.184.00
986.331.183.00
I didn't see part number 98633116301 anywhere on them.
06-17-2014, 11:58 PM
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
06-18-2014, 06:14 AM
Alex, I have a 2000 S 6 speed coming in next week. If you're not in a rush, I suggest we just wait until I can verify what reinforcement plate you're suppose to get. I'm very confident I know which one you need now, but why rush it if we don't have too.
06-18-2014, 01:06 PM
That's fine. The transmission showed up today, so I'll be futzing with that for a few days. The heat shield will probably show up around the time when I need it. I appreciate your desire to get it right!
06-25-2014, 12:54 PM
I got that 2000 6 speed today. Took a look underneath to confirm what pan goes with what car.
The following part numbers are off the rubber air baffle/splash guard that are riveted to the aluminum pan and really dictate which one you should use with what car. All three rubber baffle/splash shields are shaped differently.
986.331.184.00 =3.2 with a 6 speed (maybe the 3.2 tiptronic too)
These next two, I'm making an educated guess by what boxsters I've taken apart
986.331.183.00 =2.5 with the 5 speed (maybe 2.7 5 speed too)
986.331.183.01 = this last one I'm not sure of. it could be a 2.5 tip, 3.2 tip or 2.7 5 speed
06-25-2014, 11:45 PM
Nice sleuthing, Woody! It looks like that first one is the one for me. Can you send along the mounting hardware with it? Can you PM or email your payment info to me?
Alex
06-26-2014, 08:01 PM
top is 400
middle is 300
and bottom is 301
bsnman, About to send you a pm
