Old 09-25-2013, 01:27 PM   #1
another 996 plenum and tb question
Ok guys,
i have another question regarding the 996 plenum and tb question
i currently have a 996 c4 3.6l 996 plenum and tb in my shop.
current size is 74mm,
is it a direct bolt-on to a stock 3.2l motor?
or i need to buy reducers hoses?
would you invest more and go to a 76mm size?
im currently running straight pipe, except i still have the stock headers(cats)
has anyone been running a bigger straight pipe system?
i cant remember the size of the stock piping but, would there be any benefice to go to 1.5in instead of 1in? numbers for reference only
thanks
Paseb is offline   Reply With Quote
Old 09-25-2013, 01:59 PM   #2
edc
550 Anniversary
edc's Avatar
You can stretch your rubber hose couplers over and they provide a better fit than the reducers I tried. I used 83mm from MAF to TB. http://www.boxa.net/forum/index.php?showtopic=53075&page=9
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 09-25-2013, 02:10 PM   #3
BYprodriver's Avatar
Boxster T/B = 68mm
996 C2 T/B = 74,75,76mm depending on who is measuring.
996GT3 T/B = 83mm
Boxster muffler inlet = 1.5" so that should be your pipe size.
Old 09-26-2013, 06:36 AM   #4
thanks guys,
so i will just go with the 996 c2 plenum and tb
can i increase the size piping to 1 3/4" or even 2" ? would it gives any power gains? or i just leave the stock piping at 1.5" and only upgrade to 996 plenum and tb ?
Old 09-26-2013, 09:44 AM   #5
Originally Posted by Paseb View Post
thanks guys,
You always work on the weakest link. If your muffler inlet is 1.5" there is no need to go bigger upstream. To my knowledge Fabspeed is the only muffler with a bigger inlet (2") & they include the secondary pipes (2")
Old 09-27-2013, 05:07 AM   #6
why not putting a bigger exhaust size?
you had more air to the engine
im still using the stock headers with cats, but after that, im straight pipe.
from the 3 bolts flanges, i would run a bigger straight pipe ie 2'' instead on the stock piping size
