Old 09-11-2013, 09:33 AM   #1
pjq
Siezed exhaust flange studs
04 S 6 spd
Exhaust flange. Any suggestions how to get these stud bolts outs?Are they a tapered fit, a key way or just rusted in? Thats penetrating oil on the studs now.
I broke them when I twisted them off back in February to remove the engine.
Old 09-11-2013, 10:02 AM   #2
BYprodriver's Avatar
They should hammer out easily.
Old 09-11-2013, 10:54 AM   #3
pjq
Bypro, thats what I was hoping but is not the case.
The thin head of the bolt is round not hex, could it be a bolt with splines on it?I don't see any spot weld on it, it is factory original.
One of the three flange nuts is spot welded to the flange.
Old 09-11-2013, 01:12 PM   #4
Yes it is splined with a interference fit. Maybe you can support the flange around the bolt with a pipe or socket enough to use a BFH.
Old 09-11-2013, 01:28 PM   #5
Trey T's Avatar
I used grinder and drill out
Trey T is offline   Reply With Quote
Old 09-11-2013, 02:01 PM   #6
pjq
thanks Bypro, the pic shows what i've tried so far. With this 3 " clamp and penetrating oil and stricking the edge of the flange with a hammer still no luck. Its been under pressure for 1.5 hrs now. After your post, I like the BFH but can't support the muffler, I removed the little 3" clamp and now have a 8" clamp and tightened with a pipe. Still no movement.
What about grinding the head off and drilling out the stud?
If I need Oxy Acetylene I'll have to wait until tomorrow and take the whole muffler assembly to a welding shop.
Old 09-11-2013, 02:03 PM   #7
pjq
Thanks Trey T that will be my project for this evening.
Old 09-11-2013, 03:26 PM   #8
Trey T's Avatar
upgrade it to spring bolt/nut type that Honda uses for their exhaust systems. You can find it locally
Old 09-11-2013, 05:05 PM   #9
Heat the surrounding area around the stud cherry hot and hammer it out. It is the easiest way. I have done dozens of them this way.
Blake Meredith
Flat 6 Innovations Engine Shop Foreman
bam914 is offline   Reply With Quote
Old 09-11-2013, 06:44 PM   #10
pjq
Yes Bypro it was splined and the spline is the full depth of the flange. I cut them off and drilled them out, I wish I had oxy acteylene.
Trey T I'll check with Honda tomorrow.
Here is the head of the bolt and a portion of the splined area of the bolt.
Old 09-11-2013, 08:09 PM   #11
Trey T's Avatar
you don't have to get it from the stealership Honda, get it from autopart store like autozone
Old 09-13-2013, 05:54 AM   #12
pjq
I used 8x30x1.25 bolt (8 hardness) with copper nuts, and copper never-seize. At the auto parts stores and honda and vw I could not find an exhaust bolt of this size. They did have studs but no bolts. After talking to one of the muffler shops they said a #5 or #8 bolt is good, DON'T use a stainless bolt.
