Old 09-04-2013, 08:01 AM   #1
How do I reset the engine, learning mode?
I had to unplug my battery, now the low end power just seems flat.
I recall that there is a learning mode or time frame or something.
So I unplugged, entered the radio code and went on a spirited drive. That didn't help.
I searched...
Thanks@!
'02 Boxster Seal Grey or is it Gray?
-Alexandria, VA-
BobMarley1 is offline   Reply With Quote
Old 09-04-2013, 12:51 PM   #2
Learning mode in the ECU happens automatically. The best thing to do is drive spiritedly in varying conditions (city and open road) along with a few start/stops that encompass about 50 miles over a couple of days.
Don't expect miracles in terms of additional power as the learning mode is intended to optimize engine performance for controlling emissions not maximizing power (though a clean running engine will typically produce ever slightly more power).
Old 09-05-2013, 01:56 AM   #3
Steve Tinker's Avatar
Not quite true stoney ...
After disconnection of the battery, you have to reset the system by turning on the ignition (without starting the engine), for +/- 60 seconds, then switch off the ignition and remove the key for 10 seconds.
Restart car as normal.
2001 MV Agusta F4.
Old 09-05-2013, 09:17 PM   #4
Interesting. I've never heard this nor seen any shop do it. Everyone I know simply disconnects the battery for a bit to clear the ECU. Then re-connect and it is supposed to start fresh. I'll test both approaches and post the results...
Old 09-06-2013, 06:23 AM   #5
Nine8Six's Avatar
Wow looks like I've never reset my ecu then. Tried however! Changed every possible sensors and other things can't remember what, all needed me to reset the ecu.
Like the OP I was simply unplugging the POS off the battery for 30min and that was it loll
Learning everyday, great forum!
Old 09-06-2013, 07:02 AM   #6
kk2002s's Avatar
If you do not do the reset routine will the car simply use the baseline that is already learned by the ECU?
I disconnected battery to do some door work and I just restarted, drove around the block to make sure the car ran ok. Then drove to work the next day.
Curious thing is that a few days later it appears my Fuel pump relay went bad.
Coincident or cause?
I hate when I try and do the right thing and get smacked down
Seal Grey
Old 09-06-2013, 12:51 PM   #7
Thanks guys! I guess I haven't driven it enough, although yesterday it did get better, after doing the key in the ignition thing...
-Alexandria, VA-
Old 09-06-2013, 06:25 PM   #8
Bob - "doing the key in the ignition thing" just resets the ECU parameters. You need to disconnect the battery again and then "do the key thing" to get the desired results.
Some cars run really sluggishly (like mine), others not so bad. Your ECU will relearn the settings eventually, but it takes about 4 or 5 heat / cooling cycles, thats why the key thing gets it set from the word go......
2001 MV Agusta F4.
