Old 06-03-2013, 07:40 PM   #1
Need Hydrolic Clutch Connections Advise
I am replacing all my clutch lines (4) on my 98 Boxster and I am not convinced that just snapping them together will hold a pressure seal. Am I missing o rings? I checked my manual, the forums and my Porsche dealer but got no explianation ?!
Leebherron is offline   Reply With Quote
Old 06-04-2013, 06:28 AM   #2
I had to replace a clutch line a few years back, and I remember thinking the same thing but they do in fact seal up just fine.
The section that goes through the front wheel well will take a bit of fiddling to get it in place. Take lots of pics before you start so you can refer back to them if you get confused during the re=assembly.
Why are you replacing them, and why all four? Are they damaged or leaking? I had to replace mine because a chip of granite got wedged between the line and the body and gradually sawed its way through the line, resulting in the one and only time that I had to get my car flat-decked home.
'99 black 986
Old 06-06-2013, 07:20 PM   #3
Clutch Calamaty
Thanks for the reply Mark. The previous owner must have gone "off road" and pinched and tweeked all the lines ! Lee
