Old 05-25-2013, 05:59 PM   #1
Lights, camera but no action?
Went out this morning to fire up the beast and nothing. Dash lights and gauges all came on but no cranking kinda like I tried to start it without depressing the clutch. It started fine yesterday several times but did notice my radio did not have any power on the way home. I recently replaced the ignition switch. Anything I should start narrowing down?
davedeck is offline   Reply With Quote
Old 05-25-2013, 06:06 PM   #2
thom4782's Avatar
Could be time for a new battery. There wasn't an obvious warning when mine died. It started the car first thing in the morning. Twenty minutes later I went to start the car again and it wouldn't crank even though the dash looked normal. New battery and I was good to go.
Old 05-25-2013, 07:17 PM   #3
The battery is six months old but I will check it. I check the cables to make sure they were secure
Old 05-28-2013, 06:49 PM   #4
IM had the car all day and has not found the problem yet. Scary! Would a failed starter do this?
Old 05-29-2013, 12:49 PM   #5
Yes, could be the starter. My starter worked fine and then one day...poof! Dead and gone, wouldn't make a sound.
But the starter wouldn't explain the strange radio behavior, so battery/alternator/electrical is still on the list of most likely suspects.
