Old 03-10-2013, 04:59 PM   #1
Boxster roof woes
my windows come down 1/2 way while driving (usually when I hit a bump) and refuse to go back up till I unlock and relock the top (often not even then)
I hear a lot about the micro switch issues but not with this description
roof operates fine and doors don't have locking issues
I tried shimming the switch and manually pushing the switch with no effect
does this sound like a micro switch problem?
anybody have a part number?
boxster Bob is offline   Reply With Quote
Old 03-10-2013, 05:56 PM   #2
1999 base
Meir's Avatar
most likely that is your problem.
part number: 986 613 795 02
Old 03-10-2013, 07:11 PM   #3
San Diego Boxster
drbodzin's Avatar
I had the same issue. Be aware there are TWO different micro switches. When it gets compressed by the roof hood latch you will hear a clicking sound.
Compress the switch with your finger and listen for the clicks.
One type clicks ONCE and the other clicks TWICE. Make sure you replace it with the same one you currently have. I had used the wrong one and learned this as the problem was not fixed. I ended up needing the one that clicked twice. So I have a good micro switch that clicks ONCE.
If that's the one need, PM me.
drbodzin is offline   Reply With Quote
Old 03-11-2013, 04:52 PM   #4
thank you for that heads up
