Old 02-22-2012, 02:22 PM   #1
Another Wheel Question
I have a chance to purchase a set of 2006 Boxster S Wheels they are 8x18 57 offset front, 9X18 43 offset rear, my wheels are 7.5x18 50 offset front, 9x18 52 offset rear. What do I need to do to make these wheels fit my 2001 Boxster S? Thanks
travisn706 is offline   Reply With Quote
Old 02-22-2012, 03:32 PM   #2
Johnny Danger's Avatar
The short answer is that they will fit fine. The fronts will be positioned slightly inward . However, the rears will be positioned a bit further out toward the fender . Depending how aggressive you want your "stance" to be, spacers can be added to augment this effect.
Old 02-22-2012, 03:54 PM   #3
Wheel
Thank You very much, they're a lot smarter guys on here than me.
Old 02-22-2012, 11:54 PM   #4
what about some
18x 8.5 51mm
18x10 63mm
What would I need to make them fit?
Thank you
SF-Rockster is offline   Reply With Quote
Old 02-23-2012, 12:40 AM   #5
Originally Posted by SF-Rockster View Post
what about some
18x 8.5 51mm
18x10 63mm
Thank you
Hi!
You need 23mm spacers for the rear wheels, so they will fit.
www.dynamic-speed.com
SpyderRS is offline   Reply With Quote
Old 02-23-2012, 10:35 AM   #6
Originally Posted by SpyderRS View Post
Hi!
Thank you sir!
I'm going to order them now.
Old 02-23-2012, 11:29 AM   #7
Thank you sir!
Also you can order 7mm spacers for front!
Then you become this:
18x 8.5 51mm plus 7mm spacer = offset 46
18x10 63mm plus 23mm spacer = offset 40
This configuration should be perfect, but keep in mind, to use only 225/40 in front and 265/35 for rear.
Old 02-23-2012, 12:31 PM   #8
Or you could use the 987 sizes of 235/40 and 265/40.
Old 02-23-2012, 12:54 PM   #9
Sorry, but these sizes are not for the 986 Boxster !
Old 02-23-2012, 01:32 PM   #10
OK, you have me confused. You recently posted in another thread that 18x11 wheels fit on a 986???
The sizes I mentioned may not be OEM fitment to a 986, but by that logic you shouldn't use wheels from a 987 either.
Old 02-23-2012, 02:09 PM   #11
Yes, that´s right! 11 x 18 will fit on 986, but there´s a lot of modifications to do and only with 265/35 possible.
For the 986, you can not use the 987 tire sizes, their not compatible.
Old 02-23-2012, 02:16 PM   #12
As long as the wheels are hub centric (i.e. 71.6 center bore - which 986/987 wheels both are), then they're perfectly interchangeable . However, one has to carefully calculate how the difference in width and offset will effect the overall fitment between the two .
In the past, I've gone on record several times indicating that 10 inch wheel is about the widest that will properly fit on a 986 boxster .
Old 02-23-2012, 02:27 PM   #13
Sorry Johnny, I meant I was confused by Spyder's comments, I know the 986/987 wheels interchange, it's done all the time (and that the O/S has to be correct).
The 987 sizes work fine, it's been done. They will be a touch taller, but not enough to cause a problem. Some may argue they fill out the wheel well a bit better.
Old 02-23-2012, 02:31 PM   #14
I think, it´s everyones personal taste, which widths he use... for my kind of taste, 10,0 or 10,5 was not enough. My new wheels are become the widths in front 9,0 and rear 11,0 again.
Old 02-23-2012, 02:47 PM   #15
As you probably know, it's the difference in tire size that changes the overall circumference between the two. Also, keep in mind that the oem wheels used on the 987 platform vehicles typically have a much higher offset than the 986 . And, depending on one's suspension set-up, this can pose inner clearance problems . Thus, necessitating the need for spacers .
Old 02-24-2012, 07:19 PM   #16
Thanks for all the help guys!
I just bought a almost new set w/ new tires!
SSR gt-03 18"
love them on my car!
Old 02-04-2014, 04:02 AM   #17
911 Turbo 2004 18" wheels will fits to Boxster 2001 S ?
tires sizes are:
18-225-40 front (I know its ok)
18-285-35 rear (285 its ok? I know needed 265-35)
koka4ever4u is offline   Reply With Quote
Old 02-04-2014, 05:22 AM   #18
heliguy's Avatar
JD is our wheel expert, just don't ask him if 11 inch wheels will fit...he will implode.
