Old 09-03-2011, 04:18 PM   #21
The Radium King's Avatar
yup, and a lot of that has to do with tuning the exhaust to maximise exhaust gas scouring at lower rpm, improving low rpm flow efficiency while maintaining backpressure, etc., all of which supports locating the cats further downstream and improving the headers.
ps, the quote about both cats being 400 cell was made by JD in a thread from about a year ago, so caveat emptor to all.
http://986forum.com/forums/showthread.php?t=25644&highlight=600+400+cats
Old 09-03-2011, 08:44 PM   #22
Johnny Danger's Avatar
Since that thread, further research and discussion on the topic lead me to discover that the secondary cats were 600 cell . I've always been someone who strives to enhance his knowledge about things. Particularly, when there seems to be a lack of reliable information . And, by doing so, I am able to better understand what it is that I am dealing with (in this case my vehicle), and hopefully be able to pass on what I have leaned to others .
Old 09-03-2011, 09:01 PM   #23
DFW02S's Avatar
Originally Posted by 986NY
Hi Guys,
I have a 2002 Boxster S and I thinking of installing a Fabspeed secondary cat bypass pipe. These pipes eliminate the secondary cats. ...
I've got the Top Speed Pro-1 test pipes and they improve the sound at idle, making it a bit deeper. The car also sounds better as you rev it, but I don't have any recordings.
As to power increase, it's been so hot that I can't fairly judge but maybe some due to the improved flow and saving 7 pounds per side.
When the weather gets cooler in October I should notice a difference.
A worthwhile mod based on my experience.
DFW02S is offline   Reply With Quote
Old 09-04-2011, 04:20 AM   #24
I'll post before & after vids this weekend.
insite
'99 Boxster
3.4L Conversion
Old 09-04-2011, 09:22 AM   #25
I found a very helpful link to an explanation that helps understand the difference between the OEM 986 exhaust and a modified performance exhaust system (in this care, the Fabspeed Maxflo system):
http://www.fabspeed.com/videos/Boxster%20986%20Maxflo%20Muffler%20Explanation%20V ideo.wmv
This may be pretty basic for those of you who have a lot of experience with these mods, but it really helped me understand the differences between the OEM system and a performance system. Thought I'd share the link for anyone who is researching an exhaust mod for the first time.
Marburk is offline   Reply With Quote
Old 09-04-2011, 09:30 AM   #26
Originally Posted by ProjectM96
There are youtube videos of the Fabspeed Exhaust sounds from inside the car and outside. You can access them from Fabspeed.com when looking at the products, or you can go to youtube.com and manually search them.
Thanks, M96!
Old 09-05-2011, 04:01 AM   #27
shot some video w/ OEM cat pipes vs. fabspeed bypass pipes. will post today.
insite
'99 Boxster
3.4L Conversion
Old 09-05-2011, 06:12 PM   #28
some clips comparing OEM vs. bypass.
engine is a 3.4L with a custom intake, headers & a stebro race muffler. the OEM cat pipes are from the 2.5L. the bypass pipes are 2" fabspeed.
insite
'99 Boxster
3.4L Conversion
Old 09-06-2011, 05:22 AM   #29
After posting that video, I got a call from these guys .
Old 09-06-2011, 05:38 AM   #30
never exceeded 5 over.....
insite
'99 Boxster
3.4L Conversion
Old 09-06-2011, 06:54 AM   #31
jaykay's Avatar
Does current information suggest that installing secondary cat delete pipes and a Pedro style/pse style bypass exhaust muffler (modified stock s) will reduce back pressure (and therefore alter exhaust scavenging) to such a degree that there are losses in torque and power? Can one simply look at what the computer has done to ignition timing to see if it has detuned the engine via ignition retardation, to get an idea whether an exhaust system is working well? What are the stock ignition parameters and what variance would be bad as seen via the OBD port?
Yes I know dynos are the tool I am dancing around!
986 00S
Old 09-06-2011, 07:13 AM   #32
you have to consider the whole system and the REASON backpressure is a concern (it's not).
most people talk about backpressure like it provides something to the equation. well, again, we have to consider the SYSTEM. scavenging depends upon VELOCITY in the exhaust gas. the velocity is what creates vacuum at the valve outlet. if the pipes get too big early in the system, velocity stalls and pressure increases. this means no scavenging. we also have to consider that as the exhaust gasses cool, they condense a bit, leading to further loss of velocity (this is why people try to keep the heat in headers).
ideally, you'll have a properly designed header. the length & diameter of the primaries will be tuned to the engine's parameters (valve timing, duration, diameter, angle) and to the desired performance charictaristics of the user (high-band power, low-band torque). they will join into a merge collector that is a venturi. it will neck down slightly & then open up a bit (like a megaphone). the header itself will accelerate the air past the venturi (secondary flange). once this happens, you want LARGE pipes; back pressure is not a concern.
if you're using non-venturi style headers or the OEM manifold, it's not the loss of cats & backpressure that causes the problem. it's velocity loss due to the DIAMETER of the tube. the bypass pipes are all 2", but the OEM pipes are SMALL. this means that you'll lose velocity & scavenging lower in the RPM range. there may be some improvement at the high end. all else equal, removing the cats will greatly improve velocity & in turn, scavenging.
with OEM exhaust manifolds, 2" bypass pipes and the pedro muffler, you will probably lose power overall w/ the 2.5L and 2.7L motors. there MAY be some high end power gains. the 3.2L and 3.4L would probably make power.
if you go w/ decent headers on the 2.5L / 2.7L, the bypass pipes & pedro muffler will make power up high, but lose some torque. i found the 2.5L to be gutless w/ torque anyway, so i always opted for high RPM power & revved the crap out of it. much more fun for me!
insite
'99 Boxster
3.4L Conversion
Old 09-06-2011, 07:41 AM   #33
Don't worry .... I told them to give you a break away !
Old 09-06-2011, 09:18 AM   #34
i was SUPPOSED to be at the track today, but tropical storm Lee had other plans. date has been revised to 9/15.
i will take some video so you all can get an idea of exactly what a well tuned, stripped out boxster w/ a 3.4L can do when i REALLY get into the go pedal....
insite
'99 Boxster
3.4L Conversion
Old 09-06-2011, 09:35 AM   #35
Pat
Hey insite, are you still using the wheels shown in your sig? With as performance-minded as you are, I'm surprised you don't have something like an Alleggerita.
-Chuck Patterson
Old 09-06-2011, 10:14 AM   #36
believe it or not, the BBS forged 2-piece are already fairly light. at some point, i will probably go lighter, but i have a lot of other things to do first....
insite
'99 Boxster
3.4L Conversion
Old 09-06-2011, 10:38 AM   #37
jaykay's Avatar
Thanks for your thoughts......yes of course scavenge velocity is king! Can't wait to see the video. I have just had my butt kicked by 996 4/996 T
I have the same wheels from Porsche but they were three piece...BBS is actually the manufacturer. In my view it will be tough to find anything much better in 18"
986 00S
Old 09-06-2011, 10:46 AM   #38
My wheels are the Porsche version (sport classic II). I will try to deliver some payback to the 996 TT's; 1 or 2 going w/ us next week.....I think they will find it hard to keep up.
insite
'99 Boxster
3.4L Conversion
Old 09-07-2011, 02:36 PM   #39
if anyone is interested, i have some photos showing the differences between OEM, fabspeed & deluboz pipes here:
http://986forum.com/forums/showthread.php?t=30237
the deluboz prototypes (brand new) are for sale. gorgeous parts.
insite
'99 Boxster
3.4L Conversion
Old 09-09-2011, 10:25 AM   #40
I installed cat delete pipes with an all stock exhaust system. My secondaries we starting to break down, but i definitely do not feel a power loss. I believe they are downstam enough where back pressure is more trivial
dennis is offline   Reply With Quote
