Old 09-12-2010, 10:36 AM   #1
Heat exchanger clip
Hi I need some help, i have a 2000 boxster 2.7, which had a slight exhaust vibration at idle. I took it to a garage we put it on ramps and looked at the underneath. The chap showed me the catalytic converter and the heat shield above. He said the Springs/screw/bolts/clip had fallen off, this was causing the vibration. he said If I :dance: can get them he will fix it for me.
I have no idea what parts I'm looking for, can anyone help???
sandra
Sandra is offline   Reply With Quote
Old 09-12-2010, 08:16 PM   #2
Hello Sandra;
I'm pretty sure he's refering to the threaded clips (also called U Clips or J clips) that provide a thread so a screw with oversize head can hold the heat shield to the cat. Why can he figure something out with bolt nuts and oversize washers or just generic U clips is beyond me.
Seems like a simple fix to me but, if you must have the original parts I can suggest to contact ORMAI_TUNNING on his thread on the classifieds at http://986forum.com/forums/showthread.php?t=25216. He has a boxster for parts. I tried to get a Porsche part number for you but could not find it. This is an image of the OEM clip you need. There is a site that have them listed but is in UK http://www.porscheshop.co.uk/acatalog/porsche_boxster_986_exhausts.html. Heck they only cost 1.31 EU each. I'll say just go to PepBoys/Advance and find a generic one that fits...
HTH
Fred
Guaynabo, Puerto Rico
ALarracuente is offline   Reply With Quote
Old 09-12-2010, 10:17 PM   #3
BYprodriver's Avatar
If you are missing the screw that holds the heatsheild on the converter it is a odd one I have never seen anywhere else. I would just go to a Porsche dealer & order what you need.
Old 09-14-2010, 12:02 PM   #4
Thanks for the advice everyone, Sandra
