Old 08-12-2010, 06:36 PM   #1
Need help with engine error codes on 99 boxster
I have the following engine error P-codes:
P0102 (Mass air flow sensor, short to ground/below lower limit/ lean mixture threshold)
P1124 (fuel pump relay output stage, short to ground/below lower limit/lean mixture)
P1126 (oxygen sensing adaptation, lower load range, cyl. 1-3, short to B+/above upper limit/ rich mixture threshold.)
I would be immensely grateful to anyone who has ideas on where to start. Thank you soooo much!
Colby
99 2.5L Boxster: 135,800 miles, AVIC-Z2 In-dash navigation/DVD receiver w/bypass switch, made and installed Pedro's hi flow air intake, custom laser engraved wind-stop, hacked convertible top relay, de snorkeled.
Pianohawk is offline   Reply With Quote
Old 08-13-2010, 08:26 AM   #2
BYprodriver's Avatar
Only input I can offer is I have heard the fuel pump relays can go bad & a new one is $15 or less. It is easy to replace under the dash drivers side. Pull off the fuse panel cover & you should have a diagram there. I had to get a Bently manual since my diagram was missing. That may be the only problem.
Old 08-13-2010, 08:44 AM   #3
landrovered's Avatar
Lean codes can be caused by vacuum leaks , secondary air injection faults and exhaust manifold leaks.
Lean limit suggests that you have some oxygen (air) getting into the system and the pre-cat O2 is trying to compensate and it is running into the limit because the O2 is coming from the atmosphere and not from the combustion process.
That is where I would start.
2001 Boxster S 3.6L, Zeintop
Old 08-14-2010, 08:18 AM   #4
It would appear that HUALE768 is an even smarter spam bot that is now combining posts in a thread to be harder to spot. Amazing what hackers can come up with.
Old 08-17-2010, 11:21 AM   #5
Thank you for your replies! I'm going to try and clean out the MAF sensor this week and cheek the fuel relays as you suggested.
