Old 07-17-2010, 04:16 PM   #1
Johnny Danger's Avatar
Question on Catalytic Converters
I have a set of secondary cats for sale that came off of my 986 "S". I have received several inquires from other boxster owners regarding compatibility with their base model . Clearly, the headers/pre cats are completely different between the "S" and "non S". However, are the secondary cats different between the two models ? Will they work with either engine ? Does anyone know ?
Old 07-18-2010, 07:04 PM   #2
Can anyone help with the answer ? Or should I go see Mr. Whoopee ?
Old 07-19-2010, 10:02 AM   #3
BYprodriver's Avatar
1997-1999 has a smaller pipe diameter & flange 3 bolt pattern so they will not bolt together. If you are refering to 2000- 2.7 pipes I am not sure but I bet if it is same gasket part # it probably is the same.
Old 07-19-2010, 10:21 AM   #4
Yes, I am referring to the 2.7 engine. I know that the 2.5 has a completely different exhaust configuration. Thanks for pointing that out .
Old 07-19-2010, 12:58 PM   #5
Johnny, as far as I know, the 2.7 and 3.2 setups are the same by means of the secondary cats and are interchangeable.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 07-19-2010, 01:23 PM   #6
Great. Thank you.
