Old 05-24-2010, 06:05 PM   #1
Aftermarket ignition?
Hi guys,
anyone running an aftermarket ignition? I want something like an
interceptor that will allow me to dial in some retard.
J & S safegaurd is along the lines i think, but would live to hear if anyone else has anything? You forced induction guys must have something?
Sam
sparker is offline   Reply With Quote
Old 05-24-2010, 06:33 PM   #2
MSD has a "fit all" kit...crank trigger,pickup,adjustable module
extanker is offline   Reply With Quote
Old 05-24-2010, 06:38 PM   #3
This will work with a coil on plug 6 cylinder DIS? Would you happen to have a module name or part number?
Regards,
Sam
Old 05-24-2010, 07:04 PM   #4
check with MSD ...you may be able to use the crank signal from the po.
Old 05-24-2010, 07:06 PM   #5
I did check on the MSD sight, couldn't find anything other than running two MSD DIS-4's which seemed a bit extreme. Particularly seing as I don't want to improve spark strength, just want to add a step retard.
Old 05-25-2010, 03:06 AM   #6
i share your pain but the lil evil elves from the black forest aint givin up the secrets of the ECM without a fight....i~m gonna quit on my quest for a NOS install for this reason...good luck
Old 05-25-2010, 05:41 AM   #7
The J and S vampire appears to be what I need. $575 though... That being said, it is a very sweet piece of gear that would give great protection to the engine.
Sam
