Old 02-04-2010, 08:46 AM   #1
Will these wheels fit on a Boxster?
I am looking at a staggered set of wheels for my 2001 boxster.
18x10 50mm offset
18 x8 40mm offset
Will these fit on a boxster with proper tires?
2001 Seal Grey, 2.7L
drem914 is offline   Reply With Quote
Old 02-04-2010, 10:57 PM   #2
Photos would be helpful.
gschotland is offline   Reply With Quote
Old 02-05-2010, 08:14 PM   #3
Rears may be OK, but the fronts are off by 15mm the wrong direction...you should be around et55 on the fronts. By wrong direction, I mean spacers would only push them out further away from the struts; you need them closer.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 02-13-2010, 10:16 AM   #4
how about these?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390146363843&category=43959&_trksid=p4340.m263&_trkparms=algo%3DSI%26its%3DI%26itu%3DUCI%26otn%3D 9%26ps%3D63%26clkid%3D7820539579574869574
size and offset
19 x 8.5 x 45 mm front
19 x 10 x 50 mm rear
Old 02-13-2010, 12:15 PM   #5
TriGem2k's Avatar
Send a message via AIM to TriGem2k
50mm 18x10 will rub the struts. The ideal offset for 18X10 is 42mm. 48mm is the HIGHEST you can get away with.
You may get away with 45mm for the 18x8.5 however the ideal offset for 18x8.5 is 50mm. With 45mm there is a chance it will rub your fenders.
I can assure you my info is legit because I went through the exact same process when I got my wheels.
I have 18X10 rears with 48mm offsets and I use the OEM 5mm spacers which brings my offset to 43mm. My fronts are 18x8.5 with 55mm offsets no spacers however 5mm spacers would give my car a much better look I just never got around to installing them..
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
