Old 12-26-2009, 03:46 AM   #1
Widest Tire
I have the standard Boxter 17 inch wheels and was wondering if some one knows the widest tire to put on these wheels and if there is somewhere to look this information up?
mmontfort is offline   Reply With Quote
Old 12-26-2009, 06:51 AM   #2
This website has a wheel and tire calculator that may help you out...
http://www.bigcustomwheels.com/info_specs.jsp
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 12-26-2009, 08:21 PM   #3
Topless's Avatar
I have seen 285s front and rear on a 2001 Box in our club. He did have to roll the fenders though. "How wide" really just depends on your goals and your wallet.
Old 12-27-2009, 06:30 AM   #4
Wingnut2u's Avatar
I run 275's on my 01 and they barely fit without rolling the fenders. On high compression dips the tires would rub, I have since rolled my fenders and have not had any rubbing since.
I am running 18x10 in the rear, with PSS9's and the car is lowered about 1-1.5"
2001 Boxster S
RUF front bumper, Techart side skirts, Gemballa rear bumper, PSS9s, Cargraphic 18" racing wheels, RUF exhaust, GT3 seats
Wingnut2u is offline   Reply With Quote
Old 12-27-2009, 07:48 AM   #5
JMATTA, Big custom wheels is just the thing. How do you guys find this stuff. Thanks.
Old 12-27-2009, 06:46 PM   #6
This one is very good, as well.
http://www.1010tires.com/TireSizeCalculator.asp
JGM
2002 Boxster S
Old 12-29-2009, 05:39 PM   #7
Johnny Danger's Avatar
The rear set-up on my vehicle is very aggressive @ 19 x 10 +31 offset 275/30/19. In addition, the vehicle has been lowered significantly via adjustable coilovers. As far as width is concerned, this is the widest tire I could use without having clearance problems. As far as the oem 17 inch wheel is concerned, its more of an issue as to how well will such a small wheel ( in terms of width ) safely hold the bead of a wider tire. Correct me if I am wrong, but I believe that the standard Boxster 17 inch wheel is no more than 9 inches wide. If that is the case, I don't believe that you can run anything wider than say 265 and not have concerns about "rolling" a tire.
Old 12-31-2009, 05:55 AM   #8
That is true about the 9 inch wheel, if that be the case. My P-Car wrench always liked to stretch the tire, rather than have one too large for the given wheel...makes the sidewall stiffer.
JGM
2002 Boxster S
