Old 10-14-2008, 05:33 AM   #1
Should I get a header if I am keep the OEM cats?
I am putting a Fabspped exhaust on my car and wanted to know if it makes any sense to put a header on at the same time even if I am going to keep the OEM cats. I have an 2003 2.7 with manual transmission
Is it worth the investment? There are several on ebay for about $150
would love to hear all of your thoughts.
fortunato is offline   Reply With Quote
Old 10-14-2008, 11:30 AM   #2
It should be definitely worth it... your '03 has 4 cats... one on each header, and then one on each midpipe. If you put on the headers you speak of, you'll be getting rid of 2 of the cats, not to mention the aftermarket headers flow better than the oem exhaust manifolds.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 10-14-2008, 12:30 PM   #3
A contrary opinion
You only have a 2.7 flowing through those headers. You are keeping all the downstream restrictions on the exhaust. So why bother.
Compute the cost (and risk...heard of head bolts breaking off several times) per advertised HP...and ask for dyno'ed results..as advertised and reality are sometimes very different.
Old 10-14-2008, 01:40 PM   #4
edevlin's Avatar
I did a series of dyno runs when I was doing mods to my 2000 2.7L Boxster. As I recall adding a full exhaust system (headers, 100-cell cats, high-flow muffler) only added 5-10 hp to my car. And that was with a ECU chip that was specifically designed to take advantage of higher-flow exhaust system.
I know others have have found big increases in HP with just the addition of headers or mufflers, but that has not been my experience. If you just like to mess around with your car like I do, and/or if you are not concerned about potential CEL issues that can come up with exhaust mods, and/or you have the funds available, go for it.
Even if you dont realize great HP increases, your car will probably sound like it's much faster, and that works for me. BTW, if you have not already done so, I strongly encourage you to do a baseline dyno pull to see what your car is making in stock condition. That way you will be able to judge how effective the mods may be, have fun.
Ed
My Car Webpage
Old 10-14-2008, 02:46 PM   #5
Get the maxspeed motor sport headers with cats, for 799$. and get the cat delete pipes for the secondary cats. No CEl and definate increase in power. Maybe about 15-20 hp. but the sound is awsome and fun to drive.
I will have dyno results soon. I did this mod to my 02 s and it really woke it up.
James
2002 S
Old 10-15-2008, 07:02 PM   #6
If you're installing the FabSpeed exhaust (either the "new" or the "old" system), they utilize proprietary midpipes, so unless you go with FabSpeed's own catted headers, you will be catless. If you want to utilize the "eBay special" headers (which are non-catted), and you want to keep the factory secondary (now the only) cats, you will not be able to use the FabSpeed system.
For what it's worth, I'm running TurboWerx headers (non-catted) with FabSpeed's "new" exhaust (yes, I"m cat-less) with my DME flashed to RoW software, and it is fantastic. There are definite power gains to be had by getting rid of the horrible factory headers, and the much lower back pressure helps throttle response quite a bit. Sound is intoxicating as well No CEL if you run the German software.
Hope that helps.
Patrick
Old 10-15-2008, 10:53 PM   #7
Respectfully BMWM750 is incorrect.
I have Maxspeed headers with cats connected to fabspeed bypass pipes connected to a Che muffler. All hook up nice and without trouble.
James
2002 S
Old 10-16-2008, 06:16 PM   #8
James-
Unfortunately, I am not incorrect. If he wants to use the FabSpeed exhaust, it utilizes proprietary midpipes, so he would not be able to use the factory catted midpipes with the FabSpeed exhaust. Now, if he wants to use one of the other exhausts (such as you have done) with just the FabSpeed bypass pipes, that's a different story, and that can certainly be done.
So, to recap, if you want a catted system and you plan to utilize the FabSpeed exhaust, you will need either their catted headers, or the NHP headers that JHandy has purchased (which I still think look horribly designed).
Patrick
Old 11-02-2008, 05:52 PM   #9
2 cents
I would definately go with a full exhaust, but just remember that if you mix and match you may not get the best results. Each company makes their products to compliment each other. I just bought the full NHP set up although I do agree that the headers are not very pleasing to the eye. However, they did claim 5 more horse than Fabspeed, so that is why I chose them.
-Jeff-
"I'm a glutton for punishment when it comes to my boxster"
'03 S/ PSS9/ B&M short throw/ EVOMS intake/ NHP full exhaust w/ headers / Cantrell MS custom tune
boxster_s_boy_34 is offline   Reply With Quote
