Old 09-12-2008, 11:00 PM   #1
19" wheel fitment question
I'm currently in the market for some new wheels and have come across a deal for a set of 19" wheels. Problem is I'm not sure if they will fit.
The wheel specs are: 5x130 bolt pattern, 19x8.5 offset 49 in the front and 19x10 offset 53 in the rear.
Thanks in advance!
-Richard
ctkrider is offline   Reply With Quote
Old 09-17-2008, 10:10 PM   #2
The rear wheels with a 53mm offset will sit near perfect without sticking past the fenders & no need for a spacer.
The front 49mm offset might give you some clearance issues with the strut/spring assembly. At worst, you may need to add a 3-5mm spacer for clearance
Rareair is offline   Reply With Quote
