Old 08-22-2008, 11:20 AM   #1
Guys with 18" wheels, question
What rear tire size are you guys running? And what's the width of your rear wheels?
I've been doing research on getting myself a set of those Carrera 18" 5-spoke wheels but the ones for sale on ebay are 8x18 / 10x18 which is 911 sizing. I assume at least 5mm spacers for the rear is required. I believe the same wheel made for Boxster is 7.5x18 / 9x18.
My point is that running 265/35/18 on 10x18 wheel will look weird because the tires will look narrow on that size wheel. Not to mention of wheel curb if you're not careful.
Running 911 size rear - 285/30/18 = more $$$, heavier, slower acceleration.
PS: I don't think I'll be getting these until next summer, but yes I'm bored at work...!
Old 08-22-2008, 11:35 AM   #2
FTD
I'm bored at work too!
I will check the size and take pics and post them. I have the 18" 'Carrera Light' wheels, which is what I think you are interested in. I personally think they are VERY good looking, being a less is more sort of person.
Thanks for giving me something to do....
Old 08-22-2008, 11:57 AM   #3
FTD
Michelin Pilot Sport 265/35 ZR18
I don't know how to answer your other question.
Here's some poor quality pics.
Old 08-22-2008, 11:59 AM   #4
Did they come with the car when you bought it?
These 'carrera light' wheels from Porsche come in 2 set of sizes.
For 996 - 225/40/18, 8x18" front, 285/30/18, 10x18" rear
For Boxster - 225/40/18, 7.5x18" front, 265/35/18, 9x18" rear
If you have 265 rear tires then you should have the 9x18" rears. You can tell by looking at the tires if it's too narrow for the wheels.
I think they're _perrrfect_ on a Boxster without bodykit. I also agree that less is more and these 5 spokes look totally elegant. As you can tell I'm a big 5-spoke fan and my last car also had nice clean stock 5 spoke wheels.
I also like BBS-style mesh wheels but I don't think they will look nice on a boxster without bodykit.
Old 08-22-2008, 12:11 PM   #5
No spacers needed on those wheels so long as you get the 18x10 with Boxster offset. Check out the Bridgestone Potenza RE050A Pole Position 265/35ZR18. I believe the tire is a little wider than most other 265/18. It's what I use.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 08-22-2008, 12:46 PM   #6
TriGem2k's Avatar
Send a message via AIM to TriGem2k
I run 18X10 rears offset at 48mm with 5mm spacers. Final offset is 43mm with a rear size of 285/30/18...
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 08-22-2008, 02:06 PM   #7
I run the 18" Carrera Lightweights on the street... in boxster ET... I run 275 toyo's in the rear. When I was researching these wheels, I was obviously looking for them in 986 ET, but they were hard to find. The 996 ET wheels have to have at least a 15mm spacer, and a good rule of thumb is stay under 275, although some people have run 285 if it is a narrow running tire type. I believe those that run 10" ~ET65 (996 size) rear wheels have to tie off the parking break line as well...
hope this helps
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 08-22-2008, 02:36 PM   #8
07 Carrera S Cab
Boxtaboy's Avatar
I run 18 inch SSR GT3 wheels with no spacers. Specs are below
Fronts 18x8 / 5-130 / ET49 - Tires 225/40
Rears 18x9.5 / 5-130/ ET43 - Tires 265/35
Old 08-22-2008, 04:43 PM   #9
Boxtaboy, I love those rims!
I'm running the same but with 275/35 ZR18s in the rear. It does give you more coverage width wise. You can go as wide as the 285 but it is not necessary. Hope this helps.
porsche986spyder is offline   Reply With Quote
Old 08-22-2008, 04:43 PM   #10
It all depends on the offset if you need spacers or not, not the width of the rim. I run 18x10 ET45 BBS wheels on my car, and its a perfect fit. Most of the Carerra wheels you see are ET65, which will require a giant 20mm spacer. Search carefully, you can find wheels that require no spacers for our cars.
As to the second part, I run a 265/35-18. A 285/30 fits, and one can argue looks better, but it will also enhance understeer.
Patrick
Old 08-22-2008, 06:10 PM   #11
07 Carrera S Cab
Boxtaboy's Avatar
Thanks dude. I'll trade for your bodykit.
Old 08-22-2008, 07:09 PM   #12
Send a message via AIM to EvilTwin
I run a 18x10 et65 new turbo wheel and I needed to run a 18mm spacer to get the final offset right. I run a Yokohama S Drive tire in the 265/35 and it fits perfect. I know that some tires do run on the large size and I would look at some of the new Goodyears if you want to run the 265 width on the 10" wheel. The new Eagle F1 All Season runs almost a full size bigger.
EvilTwin is offline   Reply With Quote
Old 08-23-2008, 09:42 AM   #13
I am running 18x8.5 with 245/40s in the front and 10x18 with 275/35s in the rear (PS2s). I'm not sure of the offsets but the wheels were custom made by CCW with the right offset so I wouldn't need spacers. I just told them that I was running stock 7.5s and 9s with 7mm and 15mm spacers and I wanted roughly the same stance with no rubbbing and no need to roll the fenders. Those guys really know their stuff.
Ofishbein is offline   Reply With Quote
Old 08-25-2008, 03:36 AM   #14
I have the 18" Light Alloy turbo look wheels on a 2000 boxster. According to the sticker on the car, $2,735.00 option in 2000. I don't think I have any spacers.
Thinking about changing my wheels. Let me know if you are interested. I can send pics if you want.
Eric
E Kaplan is offline   Reply With Quote
Old 08-25-2008, 11:53 AM   #15
ekam,
My car has 18's and I am running 225/40ZR18 front and 265/35RR18 rear.
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 12-30-2008, 09:04 AM   #16
So, should I pay $1200 for replicas or $3k for a new set from wheels enhancement???
Old 12-30-2008, 10:51 AM   #17
I vote for new the real thing, maybe even used. UNLESS you do no AX, track, or spirited driving.
With replicas you never quite know what you're getting.
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
Old 12-30-2008, 10:59 AM   #18
For which rims?
On the Carrera Light replicas I have, I think they look better than the real thing, and here's why: In the rear, authentic wheels have a concave look to them. The replicas are flush with the car, and stick out as if they have spacers. Basically they appear to be wider.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 12-30-2008, 11:42 AM   #19
You mean like these (with no body kit)
Chippy is offline   Reply With Quote
Old 12-30-2008, 12:37 PM   #20
Don't get me wrong, they're very nice wheels but I think meshies break the lines on the boxster. The wheels look more aggressive than the car unless you put a kit on to balance it.
And as a general disclaimer, you can take my comment with a grain of salt. Humans not sheep so opinions makes us different. That and the saying about everybody got ****************************s & opinions...
