Old 04-06-2008, 12:55 PM   #1
power steering reservoir leak
I haven't had much time to work on the Box (or get on the forums for that matter), however, today was sunny and I thought I'd take it for a spin. Wasn't to be.
The power steering reservoir was bone dry and it sounded like it.
I believe the leak is coming from where the reservoir meets the tube connected to it as there's an accumulation right below on the engine. Is there a gasket that's gone? Anybody know what needs to be done to remedy the situation?
Thanks.
wanna986 is offline   Reply With Quote
Old 04-06-2008, 01:56 PM   #2
Isn't there an O ring that seals that up?
97 Boxster (Willy)
82 911SC (Lanna)
02 MB C240 (Eartha)
Go Army
Rick V is offline   Reply With Quote
Old 04-06-2008, 03:37 PM   #3
Is your car a S? Have you tracked it hard? A common problem on S's that are tracked hard is that the red oring/ clip that connects the reservoir to the return line will melt causing a leak... this may be your culprit, but check your connections under your car as well...
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
Old 04-06-2008, 08:01 PM   #4
Don't know about being tracked....
Is the O-ring easily replaced or do I have to get a complete reservoir?
Should I just pull up on the reservoir to disconnect and inspect?
Old 03-10-2009, 06:22 PM   #5
Same problem happens to me! Do I have a lot of stuff to remove in order to have access under the steering fluid reservoir? Does anybody have a procedure for this fix?
mynewtoy is offline   Reply With Quote
