Old 02-29-2008, 10:45 PM   #1
Tire fit question
I have a 98 Boxster and was wondering if anyone knows if you can fit a 275/40 18X10 set up in the back. If you can what do you need to do to make it fit?
hattrick_35 is offline   Reply With Quote
Old 02-29-2008, 11:47 PM   #2
With the right offset, 275/35/18 tires (not 275/40) on 18" x 10" wheels should fit in the rear.
I think correct offset would be about ET45, more or less. May require some rolling of the fender lip.
tracke30m3 is offline   Reply With Quote
Old 03-01-2008, 02:01 AM   #3
275/40 no
275/35 maybe.
285/30 yes.
i have not personally, but i've seen several that have. and the 285/30 is much shorter, so it will be less likely to rub given the same offsets as the 275/35
after seeing what my 265/35 looks like, i have no doubt the right offset wheel would work with a 285/30 with no fender work.
http://b-ng.com/audi/images/avatar.jpg
Benny
lubrify.com
Benny986 is offline   Reply With Quote
Old 03-01-2008, 07:31 AM   #4
A little more info
Thanks for the info. What spacers would the 285/30's need? Or is the best bet the 265/35's?
Old 03-01-2008, 12:22 PM   #5
Some items to think about
1) Wheel Offset
2) Is the car lowered or not?
3) Camber setting
4) Rolled fender lips.
Yes, a 10" rim can fit, but you need to consider the above.
Porsche DID offer a 9x18 wheel for the rear of the boxster. Factory tire size was 265 width... I ran 275/35-18 rears. You might use this factory size and place a small spacer (5mm or less) to help fill out the rear fenderwell, if that was a goal.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 03-03-2008, 01:52 AM   #6
see above. are you lowered? camber? what suspension are you running? does it have a big spring? or a 2.25 wide one? then look at what you have now, and use some online offset calculators, and figure out what you can fit back there.
ideally borrow the exact wheel/tire size that you want to try and see if it fits. if not, then, get 2-3 different sized wheels, with different sized tires that you have access to, then try them all and measure your clearances, and then you can figure out what size wheels/spacers and tires to get.
thats how i squeezed a 255 on a 9.5 up front. and to tell you the truth, i bet i could have gone 10 wide and gotten a wider tire up front, but this is good enough for me.
Benny
lubrify.com
