Old 11-05-2007, 07:05 AM   #1
Speed in gears
Does anyone know the speeds at fuel cutoff for 2005+ Boxsters (non-S) with both 5 and 6 speed trannys? And/or does anyone know the rear axle ratios for 2005+ Boxsters (non-S) with 5 and 6 speed trannys?
Thanks,
Alan
renzop is offline   Reply With Quote
Old 11-05-2007, 04:05 PM   #2
The speeds are mentioned in my 2002 S's manual, so I'd guess it should be in your manual as well. Look for it near the back, in the Appendices I think.
Alex L is offline   Reply With Quote
Old 11-05-2007, 05:04 PM   #3
bmussatti
Guest
Posts: n/a
Fuel cut-off is done by the rev-limiter. So about 7,200 RPM's.
Old 11-05-2007, 05:12 PM   #4
bmussatti
Guest
Posts: n/a
Gear ratios for the 2005 and 2006 Boxster (non S) :
Gear Manaul Tip
1st 3.5 3.66
2nd 2.12 2.00
3rd 1.43 1.41
4th 1.09 1.00
5th 0.84 0.74
Rev. 3.44 4.10
