Old 10-19-2007, 09:43 AM   #1
Send a message via MSN to CJ_Boxster
Smile Front Track arms replaced!
Yesterday I replaced my front suspension track arms due to wear, they chattered just like the rears did over small bumps and cracks in the road at low speeds.
It was a super easy install that does not require a write-up and has as many steps as changing your oil but alittle easier.
I used Che's (Delubozparts) adjustible Adjustible Track arms. Now my Boxster is very quiet on the road with no suspension chatter whatsoever. I also notice when im braking is much more responsive, could be placebo effect but it definatly feels more firm and tight in the frontend of the car.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-19-2007, 03:12 PM   #2
Can you be more specific... did you change the lower control arms or the sway bar links? Haven't heard anything called a "track arm".
Thanks!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
Old 10-19-2007, 04:15 PM   #3
The Front control arm Track arm, It bolts to the lower control arm then connects to the front of the chasis, since its adjustible i can now adjust caster with it... No its got nothing todo with swaybar links.
Its part #3 in the picture.
Carlos J Cazares
