Old 08-16-2007, 11:06 PM   #1
Send a message via AIM to chpanther69
CryO2 products
anyone tried any of these products on your porsche? i was thinking of getting the intercooler sprayer and the CryO2 fuel bar. check it out if you want the website is http://www.designengineering.com/products.asp?m=sc&cid=1
chpanther69 is offline   Reply With Quote
Old 08-17-2007, 07:16 AM   #2
If you look at the Boxster intake design it's already a 'cold air' system,bringing in air from the outside not from the engine compartment.
That kit is overkill.
Old 08-17-2007, 08:18 AM   #3
that and there's really not that much heat to get rid of in a normally aspirated car.
the process of pressurizing the manifold air via supercharger / turbocharger really heats up the air (pV = nRT). intercoolers help; the kits you're looking at are designed to increase the intercooler's ability to do its job. it would do almost nothing on NA cars.
insite
'99 Boxster
3.4L Conversion
Old 08-17-2007, 10:21 AM   #4
Unless you've turbocharged or supercharged your Boxster, you don't have an intercooler to spray...
Also, adding a CO2 cooler to your fuel line would be rather silly if that's all you were doing with CO2. If you've already got a nitrous system on your car, perhaps then you might consider something like that.
2005 Seal Grey Boxster S
987 Amberectomy
eslai is offline   Reply With Quote
Old 08-20-2007, 09:36 AM   #5
Blink,
How is the existing Boxster intake system "cold air" ? I thought the two vents on the Boxster suck air into the engine bay and push air out ? Isn't the air filter still pulling air from the engine bay ? If it's 100 degrees out, wouldn't the engine be sucking in warm air ?
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
Old 08-20-2007, 11:17 AM   #6
Originally Posted by NickCats
How is the existing Boxster intake system "cold air" ? I thought the two vents on the Boxster suck air into the engine bay and push air out ? Isn't the air filter still pulling air from the engine bay ? If it's 100 degrees out, wouldn't the engine be sucking in warm air?
the airbox draws air directly from the left vent. the right vent is heat exhaust.
insite
'99 Boxster
3.4L Conversion
Old 08-20-2007, 11:48 AM   #7
Blink,
Nick
Nick,
When you go home tonight look through the driver side intake vent. You should be able to see the air intake system,it's a square shaped box thing-a-bob that should have this tube leading from it(you won't have the tube if you've desnorkeled). Despite the system stills being in the engine compartment it's considered a 'cold air' design because it's a closed off from the engine heat all the way to the throttle body.
Old 08-20-2007, 11:58 AM   #8
Thanks, guys, I did not know the airbox pulled air directly from the left vent
So, if there was a way to cool the air coming in from the vent before it reaches the airbox would that be advantageous ?
Nick
1999 986 ( Black )
