05-15-2007, 10:50 AM
#21
Originally Posted by 01986
thought about that one, just think that look is not aggresive... and also would
like somthing different.. thought about the turbo twist too... but too many ppl
have them... just my thought....
turbo twists were a factory option at one point, that may be the reason. although, there must be different styles of turbo twists. I was looking at my car sitting next to my dad's turbo and his wheels are still different than mine. Same year, mine are authentic turbo rims as they have a 996 part number on the back, but a slightly different pattern. His look more aggressive than mine.
05-15-2007, 02:52 PM
#22
i didn't meen 'turbo twists' per se, i meant TURBO, as in from a 996 turbo. the 8.5" front and 11" rears with these offsets are directly from the turbo.
05-16-2007, 06:14 PM
#23
they fit under the fender
18 x 10.5 275/35 ZR18
they seem to fit just fine, no rubbing
I had to put on 7MM spacers to clear the springs.
James
2002 S
05-23-2007, 09:09 PM
#24
James
What was offset in this wheel?
Thanks,
Jake
01 Boxster S
05-24-2007, 05:43 AM
#25
These are sexy wheels. Who makes them?
05-24-2007, 09:24 PM
#26
I am running 993 Turbo hollow spokes, which are 18x10 at the rear with ET40 offset, no spacers. The ET40 pushes the wheel about 5mm too far outboard. It is fine with stock suspension, but I'd be worried going lower with running major camber.
Patrick
05-25-2007, 11:17 AM
#27
LowflyR
Size (front) 18x8.5
Size (rear) 18x10
Finish Silver
Offset 52MM-F, 58MM-R
Bolt Pattern 5x130
http://tinyurl.com/2gc4q6
2002 S
05-27-2007, 03:39 AM
#28
I just ordered 7mm spacers for 10 x 18 (265/35) with 52 offset. I should be OK?
Jake
http://www.jazmine.com/images/avatar.jpg
My FB has lots of pics
01 Speed Yellow Boxster S
- Tip
- PSE
- C4S Cluster with new style OBC
- 18" with 7mm rear spacers
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- Integrated Garage Door Opener
- 986 emblem
- Yellow brake calipers with Brembo stickers
- Yellow center console
- Aerokit II wing & trunklid
- Eibach Pro springs
In memoriam: Black 935 Street
06-01-2007, 12:02 AM
#29
Now I know I'm OK. Yesterday I got my spacers and 52mm offset 10x18 are OK even with 5mm spacers.
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
06-02-2007, 08:13 PM
#30
That puts you at ET47, which is generally considered ideal for Boxster fitment.
Patrick
06-03-2007, 12:00 AM
#31
It worked Great
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
06-05-2007, 09:33 PM
#32
wheel Fitment
I got 18x10 rear with offset 48mm and 18x8 front what size spacer do i need to fit the front and rear?
06-05-2007, 09:50 PM
#33
I don't think you need any spacers. My 8x18's are 48 offset and they fitted fine and my 10x18's (offset 52) fitted ok with 5mm spacers. It will be pretty tight clearance to the strut at rear though.
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
06-05-2007, 10:01 PM
#34
I Got 98 Boxster, I got 18x10 with 255/35/18 but for some reason its rubbing on the strut tower so do i need any spacers?
