Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Off Topic > Off Topic Discussions
Old 09-11-2024, 02:39 AM   #1
Can JPRO perform bi-directional vehicle tests?
Yes, JPRO can perform bidirectional vehicle testing.
Bidirectional testing allows you to not only read and clear diagnostic trouble codes but also to interact with and control various vehicle functions and components. With JPRO, you can:
- Activate or Deactivate Components: Test components such as relays, actuators, and solenoids by sending commands to them from the diagnostic tool.
- Run Diagnostic Tests: Perform specific tests, such as fuel injector activation or ABS pump activation, to verify component functionality.
- Control System Functions: Adjust settings or perform system calibrations, like adjusting idle speed or performing a DPF regeneration.
To use bidirectional testing features effectively:
1. Connect JPRO to the Vehicle: Ensure proper connection using the appropriate adapter for the vehicle.
2. Access the Diagnostic Menu: Navigate to the section of the JPRO software that offers bidirectional control or special tests.
3. Select the Component or System: Choose the component or system you wish to test or control.
4. Perform the Test: Follow the prompts to activate or deactivate the component or run the desired diagnostic test.
Make sure you refer to the JPRO user manual or technical support for specific instructions and capabilities related to your vehicle and the software version you are using.
If you want more help, visit OBD2.LTD
Antoine86 is offline   Reply With Quote
Old 10-02-2024, 09:05 AM   #2
Does JPRO support all vehicle types for bidirectional testing, or are there specific vehicle models or systems it's compatible with?
BlakeRevenant is offline   Reply With Quote
Old 10-02-2024, 10:41 AM   #3
Moderator
Bill Ladd is online now   Reply With Quote
