Old 09-05-2023, 06:41 AM   #1
Cigarette Lighter power off ability?
Is there some hack to change the cig lighter from always being on to turning off when I turn off the car? I want to put a USB adapter in it, but don't want to have to pull it each time I turn off the car.
Thanks.
JSLong is online now   Reply With Quote
Old 09-05-2023, 07:35 AM   #2
The lighter is always hot so that you can plug a battery maintainer into it.
Old 09-06-2023, 07:04 AM   #3
1998 Boxster Silver/Red
Thanks.
I plugged a UB adapter into my cig lighter... 7 years ago. I've never been compelled to remove it.
Why is it necessary to remove it each time you leave the car? What's the deal?
1998 Porsche Boxster
Old 09-06-2023, 07:28 AM   #4
If a 986, you could always replace constant + on plug w switched + from the phone option plug buried at base of center column (or pulling line from fuse panel if 987 or 986). Or just add USB plug in dash w +12V switched power from phone plug (or again via pulling line from puse panel if 987 or 986) and leave cig lighter plug available for battery mainter use.
Good luck
"Cool Prius!"
- Nobody
Old 03-06-2024, 10:22 PM   #5
you can leave it there all the time, if it has a little led light and you are worried that it would drain your battery, don't worry, they use very little power
MasterDesigner is offline   Reply With Quote
Old 10-28-2024, 11:52 AM   #6
When looking into the same issue I came across this video on YouTube ( it has English subtitles ). Seems like a reasonable way to solve the problem: https://youtu.be/vgE-5sXXbAs?si=V-XY6EhGOBGKyQLT
BoxsterInTheSun is offline   Reply With Quote
Old 11-04-2024, 09:18 PM   #7
I did a similar thing except I didn't want to cut any wires.
Instead I removed the output pins of the cigarette lighter and phone connection fuses and swapped them.
Depinning the fuse fox connectors is a pain but in my opinion worth it.
Makrilli is offline   Reply With Quote
