Old 11-04-2019, 06:17 PM   #1
DIY: Replace Brake Lines (Stainless Steel)
New DIY: Replaced my brake lines with stainless steel. While I had the calipers off to paint them I went ahead and did this upgrade, but split the DIY into two videos.
https://youtu.be/N4S2_vYf_Qw
1998 Boxster
2015 BMW M4 Dinan Stage 3
2016 BMW S1000XR
2015 Ninja 300
TTGator is offline   Reply With Quote
Old 11-05-2019, 06:20 AM   #2
1998 Boxster Silver/Red
PB Blaster is your friend, and mitigates mucking up those delicate lines nuts.
1998 Porsche Boxster
Old 11-05-2019, 06:22 AM   #3
Trust me I went through A LOT of PB Blaster... to no avail.
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 11-05-2019, 10:49 AM   #4
Oh, Man. I imagine your car went through some weather over the miles. I used PB Blaster and mine came off like a breeze. Further I imagine you must have been white-knuckling it... because those lines can be very delicate and one mis-step...
Again, great vid! And, again, I REALLY like how you don't abbreviate by editing out all the real challenges. Your delivery is very measured... and you are very patient.
What's next on your DIY roster? I'm looking forward to it!
Old 11-05-2019, 11:38 AM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
Great video as always.
I put on SS lines last year and did a full fluid flush at the same time. Having the proper flare nut wrenches and using extreme care and control is so important. As it is I ended up rounding one of the hard line nuts but it tightened enough. I bought a replacement hard line and I will install it when I do my next brake fluid flush.
Keep up the great videos. Yours are some of the best!
Old 11-05-2019, 11:51 AM   #6
Thanks man! I left two of them in white vinegar overnight, PB Blaster, heat, repeat, vice grips, and they are still together. Finally had to order two new ones with the brackets. Ugh. They come tomorrow, so the car is still on the lift.
After that I'll flush the brake fluid of course, and get that posted
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 11-05-2019, 11:53 AM   #7
Thanks so much! Means a lot. And thanks to all for the subscriptions, likes, and support!
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
Old 11-09-2019, 05:30 PM   #8
jaykay's Avatar
Nice realistic video!
Is your new paint resistant against brake fluid? I think I messed mine up in one spot during a bleed way back
986 00S
Old 11-09-2019, 05:56 PM   #9
Not really... mine has already rubbed off a little around the bleed nipples where I spilled some on it.
1998 Boxster
2016 BMW S1000XR
2015 Ninja 300
