Old 08-11-2016, 04:42 AM   #1
fridsten's Avatar
Simple DIY: Battery tray refurbish
A couple of weeks ago I discovered that my battery didn't work properly. Charging it didn't work, so I guess it must have had a dead cell.
As I went out to the car to replace it, I discovered this:
Rust? In my Porsche? That won't do!
This is what it looked like after I had removed it from the car:
The underside of the tray was actually in good shape. There's also some foam padding there, so I didn't want to mess it up too bad.
After having removed all the rust by hand, and believe me when I say it took some elbow grease, I washed it with paint thinner. After that it was time for some primer:
This was applied by adding several thin layers and letting it dry for a few minutes between them. You don't want the paint to run.
When the primer had dried properly, it was time to paint it black:
I bought engine paint for this, since it's a bit more durable and can stand a bit more heat. It's probably not necessary, but since this is a utility part of the vehicle that's not for show, it felt right.
I also got some brand new stainless nuts, bolts and washers:
And the final result with the battery back in place:
This was an easy job to do and it probably doesn't even need a post in the DIY section, but it was fun to do and it might inspire some others to check the state of their battery trays, so I decided to do this anyway.
fridsten is offline   Reply With Quote
Old 08-11-2016, 06:09 AM   #2
steved0x's Avatar
Looks great!
Old 08-11-2016, 10:13 PM   #3
stelan's Avatar
Nice job!.
stelan is offline   Reply With Quote
Old 08-12-2016, 04:36 AM   #4
Crib
Nice job. Whether it's hard or not I like to see the different ideas on how to care for our babies, and when looking down onto something rusty and not ignoring it, that shows you're an enthusiast.
I will check my battery tray later today, just because :P
On a side note: Fick du bort färgen från asfalten?
Crib is offline   Reply With Quote
Old 08-12-2016, 05:21 AM   #5
2003 S, Arctic Silver, M6
paulofto's Avatar
I kind of think the asphalt looks good in red!
Old 08-12-2016, 06:18 AM   #6
2003 Base 5-speed
grc0456's Avatar
Top notch! Might have to look at mine now.
Old 08-13-2016, 01:20 AM   #7
fridsten's Avatar
Det brydde jag mig faktiskt inte om.
Old 08-25-2016, 10:24 AM   #8
Thanks for posting!
