Old 05-13-2016, 11:55 AM   #1
DIY Painted Buper Guards for about $70
Hi all, this is my 1st DIY for the Boxster. I wanted painted bumper guards so I did it myself.
I got spray base coat, clear and flexible primer from Autotouchup.com They always come through with a great product. I also bought some adhesion promoter from a local store.
Don't forget to maintain as dust free area as possible.
I removed the 2 bumper guards and cleaned them in soapy water. After they dried I used adhesion promoter (according to directions) and then sprayed several coats of the primer.
After the primer dried I lightly sanded it with 320 grit. Wiped it with paint prep to remove dust and I then added another coat of primer. Finally I sanded with 400 grit until very smooth.
After an overnight to let really dry I wiped it all with paint prep to remove any dust (tack cloth might be good here but I didn't have one)
I then sprayed a tack coat of base color and then more coats until you get full coverage and the color you like. As with all spray cans go slowly and build up your coats to avoid runs.
Finally I sprayed the clear. Again go slow and build up. I used about 3 coats but after the guards settled for a few days I am going to scuff and clear more for a deeper look.
That"s it...bolt them on and enjoy.
