Old 05-11-2016, 04:30 AM   #1
mjr
Angry drop link
tried to replace drop link but cannot remove top bolt had to give up anyone had same prob any ideas
mjr is offline   Reply With Quote
Old 05-11-2016, 06:37 AM   #2
steved0x's Avatar
Does it just spin? You have to counterhold the other side with (what I recall is) a 17mm wrench. I think the nut you remove may be 18mm.
Also, the top bolt of the drop link is what holds the strut on so if you are swapping drop links you should put a jack under the carrier to support it, or it may slide down the strut.
Edit: here is a video (that I haven't watched so don't know how useful it is) but it may have some info for you:
https://www.youtube.com/watch?v=v-voasQA17A
