09-01-2015, 03:43 PM
Water pump and thermostat gaskets
Do you need to use gasket sealant when installing a new water pump and thermostat ?
09-01-2015, 03:53 PM
If you bought the stock type embossed metal gaskets then, no sealant.
09-01-2015, 04:17 PM
Thanks, that is what I thought
09-02-2015, 07:58 PM
Just curious, were you able to stick a torque wrench in there to tighten the WP?
09-02-2015, 09:00 PM
Ill let you know this weekend when I do the actual install
just drained all the coolant and cleaned the front rads tonight
The front rads were actually pretty clean. Now I just need t remember where all the screws go LOL
09-03-2015, 06:18 AM
In case you didn't already know, there are two longer bolts on the pump. I made the mistake of not paying attention and had to go back and fix it.
09-03-2015, 08:06 AM
I did, but thanks for the heads up anyway
