01-06-2017, 05:44 PM
#381
Ben-Auto-Design
I don't think you'll feel a difference with reflective tape on the boxster, but for the price... you might try!
I put some on the first version of the plenum.
I feel that the 986 is really sensitive to outside air temp, I can feel a difference between morning power and noon power, even though it's only 10/15°F difference.
I think it has more to do with the ECU settings that advance timing when it gets hot than the actual difference in air density...
I got a new phone so I'll be able to do datalogging easily now. I'll try to collect the right info, see what's really going on!
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
01-07-2017, 04:24 PM
#382
Ben-Auto-Design
Soooo this week end I had a ton of things to do... so I decided to do something else!
I received the 996 plenum, so I made my version for the GT3 Throttle body, fairly easy since it's a straight T!
Due to its symmetrical shape, I made radial stiffening ribs (like the OEM cross over pipe)... And I really liked it!
So I tried on the 986 plenum... due to the non-symmetrical shape... it took me all afternoon...
But how cool is that!
I really like it!
It's also probably a lot stiffer... but also more expensive and a ******************** to paint...
Ben
1982 928 S Euro
01-07-2017, 10:06 PM
#383
This is some nice work Ben.
How is this comparable to the stock unit airflow-wise? Bigger means better in this case?
Still waiting for the 2.5 power kit, i.e. the car that needs it most imo lolll
01-08-2017, 03:02 PM
#384
Ben-Auto-Design
Smoother bends than the original plenum, and bigger throttle body, and yes, bigger is better on this area! The only compromise is noise. A bigger throttle body is noisier (air noises). But really, you don't notice it.
The problem with the 2.5 is: where to find a bigger throttle body? A 993 TB? Or an aftermarket one?
The plenum has the same shape as the 996 plenum, straight T, so it'll be pretty easy to make.
Thought, it is bigger than an "e-gas car" plenum, so it would be more expensive!
If someone want's to be a guinea pig, I'll be happy to work with him!
1982 928 S Euro
01-09-2017, 05:34 AM
#386
550 Anniversary
For a mechanical body 2.5 the upgrade path is the mechanical body 996 3.4.
01-14-2017, 04:38 PM
#387
Well I was ready to go back to oem configuration because my car didn't run right. Couldn't clear a misfire to cylinder 6 code after changing everything. My screwup. I switched the fuel injector wire with one of vacumm plugins so they look the same. Best news I had all year! So tomorrow I will rebuild her.
01-14-2017, 04:53 PM
#388
Ben-Auto-Design
Ahah, that happens ^^
Glad you found the problem and that it's nothing bad
1982 928 S Euro
05-03-2017, 04:12 PM
#389
Ben-Auto-Design
First 996 plenum installed!
1982 928 S Euro
05-03-2017, 05:06 PM
#390
is apparently a private post, I can't see it
I see a box with "This Facebook post is no longer available. It may have been removed or the privacy settings of the post may have changed."
email beats Private Messaging: rwalker@rwalker.com
05-04-2017, 02:20 PM
#391
Ben-Auto-Design
crap...
there it is:
1982 928 S Euro
05-06-2017, 09:29 AM
#392
Can anyone tell me if there is an aftermarket or oem throttle body and plenum combo that works with the stock intake tube on a 3.2?
The technotorque 2 is discontinued and everything else (Ben's, ipd) requires a new intake tube. It doesn't look like you can buy ipd's tube separately either.
05-06-2017, 12:48 PM
#393
Ben-Auto-Design
If you want a bigger throttle body you HAVE to use another intake tube.
The intake tube has the same diameter as the throttle body.
You can make an intake tube for pretty cheap, it shouldn't be a problem
1982 928 S Euro
06-22-2017, 02:24 PM
#394
Just to recap (sorry),
I'd buy from Ebay:
- 74mm Throttle Body
- Larger intake piping
I'd buy from you:
- 74mm plenum
So the larger intake tube would fit on to the new throttle body, which would fit onto your new plenum. Anything else I'd need?
Porsche Boxster S Type 986
06-23-2017, 03:58 PM
#395
Ben-Auto-Design
No that's all!
You already have the exhaust, I just recommend a K&N drop-in panel filter, it's cheap and worked wonder on mine!
1982 928 S Euro
06-10-2018, 11:36 AM
#396
Ben-Auto-Design
Sooo, I have been quiet lately... not because I gave up... But because I've been very busy
I'll let you guess what it is
And I spend the rest of my free time doing this... full makeover for my 986S!
I also started a website and an enterprise that will be in working order very soon !
Ben
1982 928 S Euro
06-17-2018, 11:51 AM
#397
Ben-Auto-Design
Eheheh
1982 928 S Euro
06-21-2018, 07:36 AM
#398
WTF!!! :dance: Hit us with the details Ben006!
06-21-2018, 07:46 AM
#399
Ben-Auto-Design
For now, we’re running into problems with the inner part of the mould.
It should be resolved soon with a better suited mould
1982 928 S Euro
06-23-2018, 03:54 AM
#400
Good looking stuff there Ben , but if you want a REAL challenge how about designing and producing an AOS that performs and lives in the real world ?
