03-29-2016, 05:39 PM
#261
Originally Posted by Van914
Should feel like a rifle bolt. Mine does.
I'll second that. Very positive feel to it. Gonna take some getting used to it.
And since winter just came back, might be a few days....
03-29-2016, 09:24 PM
#262
I couldn't resist, installed it today. Very impressed, thanks again.
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
03-30-2016, 06:58 AM
#263
I would really like to buy one! Please let me know of you still have one left.
03-30-2016, 08:02 AM
#264
Ben-Auto-Design
I'm starting a new round, I'll PM you right now
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
03-31-2016, 03:17 PM
#265
Yellow986S
I'm interested in one for the new round. Please pm me with pricing.
03-31-2016, 06:40 PM
#266
Ben-Auto-Design
Done
I installed a shifter today!
Took me around an hour
few tips:
-To remove the center console, it's better it the hand brake is a bit loose: it has to go high. You can also engage the 4th gear, you'll have more room to remove it.
-Get that: SureBilt/4 pcs. seal and O-Ring remover set 82030 - Read Reviews on SureBilt #82030
It can be used to remove the lower section of the mid console, pry the shift boot and access the screw hidden under the coin holder!
Trust me, it will save you a LOT of time!
-Use zip ties to mark the position of the cables in their holders, and use bigger zip ties to hold the spring compressed when you put the cable back in:
We have almost reach the minimum amount of people to start
Ben.
1982 928 S Euro
04-02-2016, 09:05 AM
#267
I have had my 99 3.4 for almost 2 years now but just now finding some time to work on, get back to the forum and discovered both of the Ben threads. Ben your enthusiasm is impressive!
PM me and let me know what info you need, I want a shifter from the next round. I haven't turned a wrench much in the last thirty years but did enjoy replacing the rotors, pads and sensors last week.
Still trying to education myself about induction options and what will work best for my 3.4. Currently the throttle response is not very smooth and I am sure there is a way to get more out of it without spending a fortune.
99 Box 3.4, PSS9's
04-02-2016, 10:33 AM
#268
Ben-Auto-Design
Pm sent
1982 928 S Euro
04-02-2016, 10:41 AM
#269
Thanks for the advice, I'll be educating myself as I now have the time to play with the boxster.
Sent my info
99 Box 3.4, PSS9's
04-04-2016, 11:09 AM
#270
I'd like to get in on a new shifter too please. I'll send you a PM
Thanks,
Jeff
1999 Boxster Base Ocean Blue Metallic 85k mi. New to me on 04/2014 w/ 83k mi.
04-04-2016, 02:24 PM
#271
Ben-Auto-Design
Done, three more available !
1982 928 S Euro
04-06-2016, 01:10 PM
#272
I replied to your PM .
04-07-2016, 05:36 AM
#273
Sent you an email, Ben.
04-07-2016, 11:08 AM
#274
Ben-Auto-Design
One more to grab!!!
I've just ordered the base shifters!
Ben.
1982 928 S Euro
04-07-2016, 05:42 PM
#275
Ben-Auto-Design
Hop, no more to grab!
Sold out for this time
Thanks guys!
Ben.
1982 928 S Euro
04-09-2016, 04:22 PM
#276
Ben-Auto-Design
Hi guys,
here is the link to follow the bearings shipment. Since it's usually to longest to arrive, you can consider that once I receive them you'll receive your shifter soon after
https://tools.usps.com/go/TrackConfirmAction?qtc_tLabels1=LK110064564HK
Ben.
1982 928 S Euro
04-15-2016, 10:33 AM
#277
Ben-Auto-Design
Here's a good mod if you have a BBSSK
I'm going to shorten the knob even more...
1982 928 S Euro
04-17-2016, 11:04 AM
#278
1998 Boxster Owner
Installed short shifter this morning - the only rookie mistake I made was not ordering a new Shift linkage Coupling, mine was fairly warn. I just ordered a new one from Parts Geek. Hardest part was removing the original shifter. I used a dremel to shave down the plastic then a large flat head screw driver to push it out. Will take it for a spin this evening - wife had to leave and I have the little ones with me.
Thanks again Ben006
04-17-2016, 01:13 PM
#279
Please let me know when you make another run of these.
Thanks.
Tony
Lapis Blue 03 Boxster S
04-17-2016, 06:48 PM
#280
Ben-Auto-Design
I will
Benitom: Cool, tell me how you like it (I hope you do!)
Looks like the shifters will be there tomorrow, and the bearings too, so everything should be done before next Monday!!
Thanks guys!
Ben.
1982 928 S Euro
