03-17-2016, 05:40 PM
#241
Received today.
Thanks Ben
03-17-2016, 05:55 PM
#242
Got mine today too.
03-17-2016, 07:35 PM
#243
G
Got mine too, looks nice,
thanks Ben
03-18-2016, 08:08 AM
#244
Tyler
I'll jump on the bandwagon - got mine yesterday!
Any tips or links to threads on installation would be appreciated.
Thanks Ben!
03-18-2016, 12:58 PM
#245
Ben-Auto-Design
Here is what you should get in the box:
The center section might have the bearing already fitted to it
Or in the cups:
It doesn't really matter, it all comes together the same!
Always leave the "one cent washer" in there (cheapest soft metal washer that fit!).
If one bearing get stuck in the cup, if you've follow the previous rule, you will have no trouble getting it out using the big set screw.
I recommend you to do the job outside the car, it takes only 4 more screws to undo, but makes it really easy.
If during installation the first bearing keeps on falling, a drop of super glue will secure it. JUST A SMALL DROP
The pelicanpart article about the short shifter installation is very good, that's what I've used the first time I did it.
The hardest parts are getting the center console out, and breaking the old plastic cups (small chisel will do the job, the white plastic is brittle and will easily break if you hit the right spot without damaging the soft black plastic.)
Good luck with your install guys! I hope you will enjoy it as much as I, and the other do
Also, there is one left to grab
Ben.
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
03-18-2016, 01:22 PM
#246
One left?
I replied to your PM Ben. Hoping that one will come my direction
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
03-20-2016, 04:51 PM
#247
Tyler
I installed mine today. Went in perfectly. Feels great. Thanks Ben!
03-20-2016, 05:30 PM
#248
Ben-Auto-Design
cool
It can feel weird the first days for some...
You might also want to check and adjust it if needed in a few weeks.
Ben.
1982 928 S Euro
03-20-2016, 06:15 PM
#249
1998 Boxster Owner
Originally Posted by Ben006
cool
Ben.
If adjustment is needed what is to be adjusted. Haven't installed mine yet just asking.
03-20-2016, 06:34 PM
#250
Ben-Auto-Design
Just the set screw:
no need to take everything apart, you should be able to adjust it by hand (Undo the nut, tighten the screw by hand).
1982 928 S Euro
03-21-2016, 08:03 AM
#251
Got mine. Can't wait to install it.
Dave in TX
03-21-2016, 05:52 PM
#252
Received in Australia, thanks!
Now to pluck up the courage to break the plastic bits on the old one...
03-21-2016, 06:00 PM
#253
Ben-Auto-Design
That was fast!
It took me around 15min and three re-reading of the tutorial to finally do it, but you'll see, it's worth it
Ben.
1982 928 S Euro
03-27-2016, 04:24 PM
#254
Ben-Auto-Design
Hi guys!
I had 5 people waiting for the next round!
Who else's in?!
Ben.
1982 928 S Euro
03-27-2016, 05:24 PM
#255
98 Arctic silver 986
I'm in........................................
03-28-2016, 06:17 PM
#256
So I just installed my new shifter and matches my marking on the cables when I reattached them and it seems like it's tight and it takes slightly more force to get into each gear. I just want to verify it should feel like this. It feels solid just different.
2001 Boxster S Arctic Silver : LN IMS Retrofit, Sport Package, AUX cable mod, de-snorkeled.
03-28-2016, 07:11 PM
#257
Ben-Auto-Design
Yes, the throw being 30% shorter, you need 30% more force to shift.
You'll get use to it don't worry, mine felt weird for a week
Ben.
1982 928 S Euro
03-28-2016, 07:26 PM
#258
Ball bearing short shifter !
Thanks for confirming. I'm excited to get out and drive it tomorrow to test it out.
Thanks again for putting together this high quality shifter!
03-29-2016, 03:59 AM
#259
Should feel like a rifle bolt. Mine does.
03-29-2016, 11:02 AM
#260
received mine last thursday, I know what I'm doing this weekend...
