Old 06-27-2018, 05:11 PM   #61
Lew
So Blessed!
Lew's Avatar
I experienced doing the small Led's on my Sailboat electrical panel using the resistors along with a green and red Led which showed on and off positions for a host of switches. Looked great....I might do my storage with a few red Led's . White light has a tendency to somewhat blind you at night.
Lew is offline   Reply With Quote
Old 06-27-2018, 08:46 PM   #62
You can control the intensity of the lights with the LED resistor. As shown in the schematics, they are not too bright...just right.
Old 06-28-2018, 12:55 AM   #63
Hi paticlewave,
nice idea, but all your interior lights have the wrong color. It has to be orange.
Now for to be a little more construtive. How about adding a motion sensor, so the light is only on if you put something or your hand into the little compartment.
You can such things pretty cheap and completely setup - for example:
https://www.banggood.com/HC-SR505-Mini-Infrared-PIR-Motion-Sensor-Precise-Infrared-Detector-Module-p-1011714.html?rmmds=search&stayold=1&cur_warehouse=CN
Or:
https://www.banggood.com/search/motion-sensor.html
Regards, Markus
Smallblock454 is online now   Reply With Quote
Old 06-28-2018, 01:20 AM   #64
What?
That is exactly what this circuit does, Markus.
I actually tried a unit similar to the one you posted, but it does not work well in such a small space or in a moving vehicle. The circuit I designed is built for a small space, accuracy and ease of construction (anyone can put the original circuit together with only a few components, regardless of electronics experience).
Old 06-28-2018, 04:34 AM   #65
Lew
So Blessed!
Lew's Avatar
PW, your mod looks nice. Since my VW Sportswagon has all it's courtesy lights in red which I really like. All of your courtesy lighting is Blue which also looks good. I might could do the OEM courtesy lighting with that color Led's. It most likely would take several since they are not to bright. Yes!
Old 06-29-2018, 11:08 AM   #66
What?
OK, i should read threads from the beginning.
And still don't have the time to do it, sorry.
Do you have a stabilized power supply for your circuit? Something like a switching power supply that generates a constant power and current?
Also do you have a potentiometer to regulate the IR circuit sensivity? I thing that's important.
Regards, Markus
Old 06-29-2018, 12:20 PM   #67
That would be overkill in such a simple circuit.
Also unnecessary. The circuit has enough tolerance to account for any voltage fluctuations and the IR emitter/detector function in a simple on/off configuration. This post is 5 years old, so the circuit has been tried and tested over the years with zero issues.
I designed it to be simple and effective. And it is just that.
