Old 10-14-2007, 09:52 AM   #1
New Radio Install - no sound
I have replaced my radio with an Eclipse AVN2210p. (me: 97 Boxster/old radio CR210 w/factory amp) Everything appears to function properly but I have no sound. I recall reading something about an output from my radio that is needed to turn on my amplier; could this be my problem?
I have been unable to find the post that mentioned it. Any help would be greatly appreciated.
Ken
kfernald is offline   Reply With Quote
Old 10-15-2007, 12:13 PM   #2
You are exactly right. You need to connect the wire that turns on the amp. Your new radio should have a wire which you can connect to the factory harness.
I had the exact same problem with my Pioneer AVIC. Its a simple fix.
I bleed green
Old 10-15-2007, 01:21 PM   #3
Thanks much, found it.
